Just change your Left/Right nomenclature and you'll be golden...(Right is the Slick, Left is the Plasma III)
Put the jumper between the R & GND (Terminal 1 in ACS parlance); This will turn the RIGHT magneto OFF when START is engaged.
Wire the Plasma III Output Connector, Pin 1 to the L terminal on key-switch
Wire the P-lead from the Slick magneto the the R terminal on key-switch.
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
