Old 05-09-2020, 10:20 PM
mdud mdud is offline
Default P-lead wire routing
I have a single mag and LSE. I'm running wiring through my firewall penetrations and I have some concern about the routing of the P-lead. I want to keep electrical noise out of engine monitor sensor wiring and the audio. I have a separate firewall penetration for the LSE RG-400 leads to the coils and I am planning on running the P-lead through the same opening. On the inside of the firewall I am not sure I should run the P-lead in the wire bundle routed to the instrument panel or keep it some distance away with a different routing. Any thoughts?
Old 05-10-2020, 12:22 AM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Shielded wire?
If you’re running properly shielded wire, you’ll likely be fine regardless of where you run it. Technically there’s little or no current on a p-lead in normal operation, creating little if any field. However, if you can run it away, or run it with high power or otherwise insensitive wiring, it’s lower risk. I ran one firewall penetration with powered stuff and main bus power, and another about six inches away for all the signal wiring FWF. My p-leads were shielded. Another effective practice is if signal and power must cross, route them such that they cross perpendicularly. It might cause the routing to look a little funny/sloppy, but some CAN related vehicle experience has proven it to work really well. Same rules go for audio/radio. YMMV.
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
Old 05-10-2020, 06:08 AM
DanH's Avatar
DanH DanH is offline
Flew about 500 hours with two p-leads in the single wiring bundle. No issues with the GRT EIS or the audio.
BTW, no flopping p-leads please.
Dan Horton
RV-8 SS
Barrett IO-390
