Old 04-28-2020, 10:15 PM
Jskyking Jskyking is offline
Default Malformed nose skin dimple
Was moving to fast this afternoon and the skin flexed as I set the dimple. Stupid mistake, setting dimples from the bottom didn?t help, but the scratches should buff out caused by the die.
Anyhow, the hole is malformed and the dimple didn?t fully form in the top left corner. When I dropped a rivet in the dimple, it?s flush With the skin but there?s a tiny space that the rivet head doesn?t cover.
An Oops rivet would probably take care of the elongated hole but the rivet head wouldn?t take up the small space on the skin.
I need to figure out a way to clean up the hole and reform the dimple.
To add insult to injury- it?s a top skin.
I?ve talked to a friend who suggested the oops, but that was before I dropped a rivet in the dimple. Hopefully, there?s a solution without having to replace the nose skin.
Jt
RV14 Empenage complete
Wings in work
Dues bypass eligible- paid anyhow
Old 04-29-2020, 09:04 AM
wirejock's Avatar
wirejock wirejock is offline
Default Dimple
Looks.like.a tiny crack needs to be dressed out or drilled one size up. If the hole is clean at that point, dimple #30 and move on. If you don't like it, add a rivet equally spaced between the two and abandon the bad hole.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-29-2020, 10:45 AM
Thanks Larry- I just got off the phone with Vans and they recommended the same. You mentioned a#30 dimple, though it’s a #40 hole. Did you mean a #40 dimple?
Wings in work
Old 04-29-2020, 11:04 AM
Kyle Boatright Kyle Boatright is online now
A #30 hole and a dimple for a standard 1/8" rivet would be my choice, along with a standard 1/8" rivet (not a reduced head rivet). That is a physically better repair, and other than the one odd sized rivet, I think is a better cosmetic repair than a smaller rivet that has to be "fixed" with filler when it is time to paint.
If there is any question about the hole, drill, dimple, and rivet a 3/32 rivet on each side of the "bad" hole.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-29-2020, 07:08 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Repair
I had a similar problem when a skin slipped just as the dimple die was coming down.
I did as suggested above i.e. installed a 1/8 AN426AD4-4 rivet in a #30 hole and dimple.
The #40 hole needs to be enlarged very carefully since you only have 1/32 inch to play with.
I would cleco the skin onto the ribs and use a round needle file to clean up and align the hole before drilling up to #30.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 04-29-2020, 07:14 PM
wirejock's Avatar
Default #30
Originally Posted by Jskyking View Post
Thanks Larry- I just got off the phone with Vans and they recommended the same. You mentioned a#30 dimple, though it?s a #40 hole. Did you mean a #40 dimple?
Nope. The hole is already drifting toward #30 with the damage. Once you drill #30, it makes sense to use a #30 dimple and standard 426 #4 rivet. Probably fit perfect and doubt anyone would ever notice.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-29-2020, 07:30 PM
PilotjohnS PilotjohnS is offline
Default Just me
If it was me, i would flatten the dimple on the skin, dress out the crack with a file and use another hole. I dont thin it is worth saving this rivet. Also driving a -4 rivet is much more difficult in this area.
I am not an expert, and I havent even finished one plane yet. So this is worth what you paid for it
I had a similar thing happen on my vertical stab. It got ugly when I tried to fix with a -4 rivet
John S
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 10% left to go
Electrical/Panel done
Firewall Forward 75%done
Fiberglass 0%, thought i was building in metal?
Old 05-05-2020, 12:32 PM
Repaired- carefully flattened dimple w/ DDRT2, drilled with #30 with a slight circular rotation of the drill bit to clean the slight crack, re-dimpled with #30 die, dropped in a #30 rivet...... drilled another #40 hole and dimpled equidistant to next rivet and put a #40 in the hole. I would have put another #40 equidistant on the other side of the repaired hole, but it fell on on a flute. Vans said I would be alright to not put any additional rivets in beside the affected mis- dimpled hole, but one or two rivets was very acceptable..... building on.
Wings in work
