Old 07-18-2014, 12:56 PM
NTex NTex is offline
Default Help identify this connection type
Does anyone that works with electronics know where to locally get this part?
It's the pigtail lead to the 460 configuration module. Guess I had too much coffee and I used my strippers to cut the white wire vs. just stripping. I need a replacement, but I'm not sure what it's called. It looks kinda like a CPU fan or a SCSI connector, but it's not.
Garmin part number 325-00122-00. I'd love to pick one up at frys or an electronics store than have to order from garmin
Thanks in advance
RV-9A finshed! For sale
Old 07-18-2014, 01:00 PM
Brantel's Avatar
Brantel Brantel is offline
There are literally hundreds of thousands of different types/designs and brands of these type connectors. Finding the exact match can be easy and can be hard depending on how lucky you are.
If you buy one, it most likely won't have the wires attached.
I would just solder on a new extension piece and put some heat shrink on it.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 07-18-2014, 01:18 PM
Ah, good idea thanks!
Old 07-19-2014, 04:51 AM
Sam Staton Sam Staton is offline
Default Connection type
This looks remarkably like the power connection from a 3 1/2" floppy disk drive (remember those ....).
RV6 N585SS - building on!
O-360-A1G6D converted to A1A
Dual Powertek EFII
VPX-Pro
Astronics PPS
Hartzell C/S
Dynon SV1000 & SV700
Old 05-01-2020, 01:27 PM
Gary2418 Gary2418 is offline
Default Connector
Were you able to source this connector? If so can you tell me where, thank you.
Old 05-01-2020, 01:36 PM
Tankerpilot75 Tankerpilot75 is offline
Try SteinAir’s website. It’s called a Moles plug. They’ve got different number of pin connections (2,3,4,6, 8, 12) available. They also sell then male and female pins. Check they’re website for several videos on how to wire things up using the various types of connections available.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 05-01-2020, 03:07 PM
fl-mike's Avatar
fl-mike fl-mike is offline
sort of looks like a JST mini micro SH series. You might be able to find a mark on the housing.
https://i.ebayimg.com/images/i/25197...-1/s-l1000.jpg
Mike W
Venice, FL
N164WM
Old 05-02-2020, 06:43 AM
bjdecker's Avatar
bjdecker bjdecker is offline
JST SHR Series 4 pin
https://order.jst-mfg.com/InternetSh...wProductDetail
https://order.jst-mfg.com/InternetSh...=1&key=eSH.pdf
The contacts are what you're needing I think -- they are JST, SSH-003T-P0.2-H
https://www.digikey.com/product-deta...3-1-ND/5725854
B
Brian Decker
Retired Firmware Guy and Airplane Builder
2020 RV-14 QB -- Under construction - Tailcone & Empennage Complete.
2018 RV-7 QB -- Built, Flying
2007 RV-7 QB -- Built, Drowned, Resurrected and flying
1998 RV-8 QB -- Started, Sold
1986 Mooney 205SE
1980 Mooney 231
Aided and abetted building a number of other RV's.
Old 05-02-2020, 12:23 PM
Mike,Brian... I think you're right. Those look pretty close. Gary, I would check that out.
Originally Posted by Tankerpilot75 View Post
Try SteinAir?s website. It?s called a Moles plug. They?ve got different number of pin connections (2,3,4,6, 8, 12) available. They also sell then male and female pins. Check they?re website for several videos on how to wire things up using the various types of connections available.
Tankerpilot75 - yes good call! Stein's a great resource for both materials knowledge. In this case, this is a pretty specialized connector. Those you linked to are Molex connectors, typically used for small current or sometimes signal wires. You'll see they (molex) are much larger than the ones in my photo.
Gary,
Blast from the past! This thread is about 6 years old... I think I ended up getting the part from Garmin. I looked into the manual and now it recommends doubling the wire connection since it's so thin.
Old 05-05-2020, 07:53 PM
PNLBLDR PNLBLDR is offline
Default In stock!
For anyone looking for this small part in the future..
https://www.steinair.com/product/gar...odule-harness/
Nick Millard
Operations Director
SteinAir, Inc.
