Old 04-30-2020, 03:27 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by N941WR View Post
Pictures please! bill (at) repucci (dot) com
Post pics here or if your gunna send pics might as well throw them my way too please! pazmany.ch@gmail.com I'll even post them for you if you want.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 04-30-2020, 03:39 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Originally Posted by DanNiendorff View Post
The best thing I did when building my hangar was to add a central I-beam with a trolley and an electric hoist. It comes in handy all the time, in ways I never dreamed of when I put it in. Even if you don't add a trolley/hoist right off the bat, add a beam that you can go back and put them on later. You will never regret it, and your back will love you for it.
And make sure the structure is strong enough to handle any weight you'll be hanging from that I-beam...............
Ed
Old 04-30-2020, 05:34 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
the end panels are not in the track at the top and the panels "flop" in and out when being pushed.
Either way, you can't put or hang anything against or on the wall.
I removed the piano hinge from the door-to-door setup, and hinged the man door to the upright frame member. The hinged door now tucks out of the way, and the tracked doors will roll much better. Also, space the "C" channel track at the top out from the side walls an inch or so. Now you can push the door without it banging on each upright column.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-30-2020, 08:15 PM
FulFab in Ohio makes hangars and they make their own doors in their factory. They have been doing this for more than 60 years. Their door motors ride on the truss above the door, which lessens the weight on the door during retraction and when sitting idle closed. They have a crew that erect the building on site. I built a row of 10 nested T?s at my airport (HAO) and the guys erected it in 5 days. Of course the pad and ramp was already installed - according to their specs. We had bids from several other hangar companies, and nothing else came close. Building erection costs from other contractors was double what FulFab charged, and the other contractors were quoting 1-2 months for the build. If you are anywhere near Ohio, consider FulFab.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 04-30-2020, 08:43 PM
bob woods bob woods is offline
Default Port a port
Bracket (Pomona) kicked all port a ports off the field. They have been moving several to chino. I was told they had a number of them they are selling?you might contact the airport for a used one
Bob
Old 04-30-2020, 09:39 PM
Jpm757 Jpm757 is online now
There is a great You Tube video online of a Port-A-Port hangar being blown over at San Luis Obispo by a CRJ doing an engine run.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 05-01-2020, 05:23 AM
Wes H Wes H is offline
Default Epoxy floor
The second best thing was to add a good quality epoxy floor - not the home depot sort, but high solids from a paint vendor. I used Sherwin Williams. Love it. Cleans up so easy. It makes a huge difference.
I put in a Hydra-Link door made by Air-Side (airsidedoors.com). I'm very happy with it. Very sturdy, and well made.
As others have said....
As large as you can
HVAC if you can
All the electrical outlets you can
Plumb for air if you can
+1 for the epoxy floor. I used SW Armor Seal 1000. Oil and gas stains are no match for this stuff and it resembles a white mirror
Wes Hewitt
RV-10 7/4/19
Emp Complete
SB Wings Complete
SB Fuse in Progress
Finish Kit on order
Engine in my possesion
2020 Donation Paid
Old 05-01-2020, 05:43 AM
wilddog wilddog is online now
Make it a lot bigger than you think you will ever need.
Old 05-01-2020, 10:50 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
I looked at that product but the reviews on Lowe's.com scared the *x*x* out of me.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 05-01-2020, 10:52 AM
Pilot135pd's Avatar
Originally Posted by rocketman1988 View Post
check them out! Awesome, self supporting door...
Yep, I've been wanting a Higher Power door for over 12 years now. Just emailed them right now to ask for a current quote. I already have manually open swing open doors I designed and they work great but for the next hangar I think I'm getting tired of manually opening them.
