Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #11
Old 04-30-2020, 12:21 AM
jliltd jliltd is offline
Does the new aera 760 have a checklist feature, either in the EFB area or other?
RV-8
(a few more airplanes too)
Old 04-30-2020, 06:34 AM
Pilotjkl Pilotjkl is offline
Will it play with my GNX 375 and GTR 200?
Commercial pilot
A&P
RV-6 0-320 160hp
Cessna 170A
King Air B200 Blackhawk conversion
2019 dues paid
Old 04-30-2020, 08:05 AM
wnplt wnplt is offline
It would very well
Old 04-30-2020, 09:56 AM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
I think Garmin decided they need to move away from tablet electronics and have a dedicated package. this will compete with the iFly 740 but overall I prefer the iFly interface over the Garmin.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 04-30-2020, 11:50 AM
Gyrodoug Gyrodoug is offline
Default 760 & autopilot?
Can the 760 drive an autopilot? If not, what is needed?
I was eyeing the G5 until this post... now I'm not sure. Or, am I looking at this completely wrong? It just seems the 760 has many features shared by the G5.
Thoughts?
Old 04-30-2020, 12:37 PM
Like the aera 660 I think the 760 can drive an autopilot, but only in conjuction WITH a G5 and maybe only for a Garmin GFC autopilot system. Clarification requestes.
RV-8
Old 04-30-2020, 03:01 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Autopilot Compatiblity
It depends on the specifications of your autopilot. If it can be driven off of a NMEA RS232 output, it should work well for you.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 04-30-2020, 03:04 PM
g3xpert's Avatar
Default Checklists
The PFD viewer would allow you to include checklists on the unit. It does not have a dedicated checklist function as the G3X Touch does however.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 07-29-2020, 03:13 AM
I just read the Aviation Consumer review of the aera 760. I was surprised by the following statement with respect to the GDL 5X(r) communication with the unit:
"Despite the aera’s ability to connect via Bluetooth or an RS-232 wired serial connection, some products—including FIS-B Cloud Tops Forecasts, Lightning, Turbulence and Icing—only work with a Bluetooth connection."
So if I hard wire the area 760 to a GDL 52 via direct wire cable does that statement imply I still can't get all the weather over RS-232? If so does that mean I need to also link the two units via Bluetooth to cover all bases?
Jim
RV-8
Old 07-29-2020, 04:56 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Jim
It certainly appears that you need a Bluetooth connection to get all FIS-B data available, based on the page shown below from the AERA 760 Pilot's Guide. If you only connect via RS-232, four data items will be missing.
Name:	Screen Shot 2020-07-29 at 3.51.07 PM.jpg
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
