04-29-2020, 07:32 AM
Standby Alternators
I would like to include a standby alternator into my electrical system for the RV10. The primary alternator included in the kit is the 60 Amp Plane Power alternator and that is what I have. I am aware of the B&C 462-H standby alternator and the 30 Amp Plane Power standby alternator. Does anyone have experience with either and are there any particular advantages or disadvantages of one versus the other?
Rick Brown
RV-14A Flying & Sold, Sadly
RV-8 Flying & Sold, Sadly
RV-10 Working on Canopy and Doors
04-29-2020, 07:51 AM
I just installed a B&C 410H unit on my new engine. It seems like a nice, compact, well built unit. Make sure you order the special tool at the same time to reach the one nut that is towards the oil filter. It wasn't that easy even with the tool so I wouldn't suggest trying it without the tool. B&C sells them.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
04-29-2020, 08:07 AM
Super Moderator
Weinstall a lot of the B&C standby alternators. The advantage is that you can adjust the output voltage as it has an external regulator that is adjustable. The disadvantage is that you have to mount the regulator.
To me it is well worth it, especially for the lithium-ion and odyssey batteries as you can adjust the output to better match the battery.
Most of the standby alternators are set to come on around 13 volts, so you really don't have to install a switch. They will begin to carry the load after the main alternator fails and the bus voltage drops below 13 volts. Initially you will think the standby is not working, as amps will read zero for a quite a while after the main alternator fails (or you turn it off for a test). Also, the standby alternators will not output anything until you are around 1500 RPMS, so again there is a chance to be fooled if you don't wait for the bus voltage to drop.
My preference is to set the standby voltage around 13.8 and the primary alternator around 14.2-14.4.
Vic
 Vic Syracuse
www.Baselegaviation.com
04-29-2020, 08:15 AM
I've got the PlanePower FS-1 as my backup and have been happy with it. Truth in lending I did have one issue -- the main case separated from the adapter base and Hartzell/PlanePower replaced it under warranty (with a new with redesigned case that eliminates this problem) even though it was a couple of years old.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
04-29-2020, 08:34 AM
alternator
I have the BC410...I wanted to use the BC462 but I have an Airwolf remote oil filter system. I found that the BC462 will not clear the Airwolf adapter that is bolted to the case...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
04-29-2020, 10:53 AM
I installed the BC410-H standby alternator on my RV-10 with the Van's standard IO-540 engine. Per discussion with B&C support folks, I installed it with their right angle oil filter adapter and their drive extension. I installed all of this before mounting the engine, which made it reasonably easy to do. It would have been much harder to do this after then engine was mounted to the airframe. Even with the engine not mounted, I still had to remove the mags in order to reach all the mounting bolts for the install.
So far, I am happy with the B&C system. But I am still early in Phase 1, so don't have a lot of run time yet to prove up the system.
Dave Macdonald
RV-10 First Flight April 1, 2020.  Currently in Phase 1
2020 VAF Dues Paid
04-29-2020, 11:07 AM
Just to chime in on the oil filter configuration. I did have to use my right angle adapter with a 0.75" spacer. Longer spacers do interfere with the B&C 410H at least but I suspect other alternators as well.
Ray Tonks
2020 Donation Paid
RV-7 SB Wings
* Ailerons Complete
* Flaps Complete
RV-7 Preview Plans
04-29-2020, 11:53 AM
Super Moderator
Yes, you have to use the spacer with both the Plane Power or the B&C.
Vic
 Vic Syracuse
04-29-2020, 03:42 PM
Have B&C 410 as only alternator and it works well. Lights are LED so load is low.
04-29-2020, 04:43 PM
Vic
No spacers required if you use the 'stock' straight oil filter adapter.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
