Old 04-24-2020, 02:12 PM
Desert Rat Desert Rat is offline
Default question re; mounting flyLed boards
For the FlyLED nav/strobe boards, the instructions suggest just sticking them on with a double sided tape like what would be used for automotive trim.
Does that work ok or are most folks doing the alternate method i.e. drill a couple of holes through a non critical part of the board for screws?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 04-24-2020, 02:51 PM
krhea krhea is online now
Default mounting
i used epoxy and flox to mount a couple of nut plates on the front centerline and side centerline and top and bottom of corners of cutouts, 1 fly led board keeps the other from going anywhere. Landing light board has three screw holes, and position and stobe has one hole.
Keith Rhea
Rv7
2020 Dues
Old 04-24-2020, 03:12 PM
tomkk's Avatar
tomkk tomkk is offline
I used screws & nutplates ...
Tom
Port Orange, Fl
EAA #51411
Old 04-24-2020, 04:25 PM
Electrogunner Electrogunner is offline
Default Tape
I used 3M double sided tape with no issues. No need to overthink it here.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 04-24-2020, 04:54 PM
ty1295 ty1295 is online now
3M tape is working fine for me, slightly not as easy to pull and work on them but no issues with them moving.
Jeff Scott
RV9A First Flight 9/30/19
Old 04-24-2020, 06:40 PM
mr.sun mr.sun is offline
I also used the automotive double stick tape. Working well still after a year.
Greg RV-7 flyer
Donated Again
Old 04-24-2020, 07:35 PM
Thanks guys.
Terry Shortt
Fuselage in process
#72651
