Originally Posted by Machsandy
I am interpreting the responses that you think the sender on the AFS 3400 is the issue?
Diagnosis 101: Always useful to compare sender-generated values with a known standard.
Is it possible that the vernatherm is the problem?
A vernatherm extends when warmed to block a cooler bypass opening. The extension is based on thermal expansion of wax capsule, a fundamental physical principle. A vernatherm can fail to extend because the wax escaped the capsule, but failing to retract is very unlikely.
I wonder whether a higher oil temp would lead to a lower pressure.
Yes, it would.
Would blocking off part of the airflow to the oil cooler be an alternative?
Some operators do that in cold weather, but 40~70F OAT isn't cold.
Is my understanding correct that if the vernatherm is working correctly then no oil should go through the cooler until a min of 180F?
No. Some oil
always flows through the cooler, although a high percentage of total pump output does short-circuit through the bypass opening when the vernatherm is cold and short. Without some flow, oil could/would congeal in the cooler passages at low OAT, blocking cooler flow, and making it unavailable if subsequently required.
By specification, a Rosta vernatherm extends 0.160" between 150F and 185F. It is expected to be fully seated in the bypass hole between 183F and 187F.
