Old 04-22-2020, 03:41 PM
wirejock's Avatar
wirejock wirejock is offline
Default CDI
I have two CDI torque wrenches.
One 1/4 and one 3/8. Covers everything.
I understand CDI makes Snap On torque wrenches.
Either way they are very nice.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-22-2020, 03:52 PM
Thermos's Avatar
Thermos Thermos is offline
Default +1 for CDI
I bought one of these CDI wrenches from Avery Tools years ago when I started my project. Cleaveland sells them now -
https://www.cleavelandtool.com/produ...18378249044030
It's not the cheapest torque wrench you'll find, but it's an excellent US-made tool.
HTH, YMMV...
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
Old 04-22-2020, 04:26 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default It doesn?t matter....
You take them both to work and cal them both! Seriously, you do the mass- distance cal or send them out. Yes, it’s happened. It’s still better to know something might be whacked, right? Admittedly, I only do this after long periods of not using them
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2020 VAF contributor
Old 04-22-2020, 04:50 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by RV7A Flyer View Post
And if they're different? Which one is wrong?
I take all of mine to a local shop every few years that can certify them back to the NIST standards. Maybe it's overkill for our planes, but IMO, there's a right way to do things...
There are a number of videos on YouTube that show how to test and calibrate torque wrenches, here is just one: https://www.youtube.com/watch?v=lZUDH13yln0
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-22-2020, 05:05 PM
Dave12 Dave12 is offline
Originally Posted by cderk View Post
I would be interested in knowing how accurate that thing is. have you compared it or calibrated it to a known good torque wrench?
I have a bunch of torque wrenches. HF and SnapOn. One is no more accurate than the other. Calibration has been checked.
Wag Aero Sport Trainer built,sold and wrecked
N588DF RV12 #336 built, sold and alive and well in New York
N73DF RV12 #244 built, sold and alive and well in Florida
N91 RV RV9 I wish I could say I built this one! Mark Santoleri hit the ball out of the park on this gem.
Currently restoring a 1978 Citabria GCBC
Old 04-23-2020, 12:05 PM
gasman gasman is offline
Originally Posted by N941WR View Post
I have a large beam style torque wrench. They don't go out of calibration, unless you drop them, which is no different than any other toque wrench.
The one I have is a Vintage Craftsman from about 1983.
They even survive a drop. Just read the scale before use and make any adjustments needed to "O". The pointer does not move during use. And the main beam can only be changed with a great amount of heat.
The main advantage is the head is a lot smaller than a click wrench that it can fit where the click won't. And they never need calibration.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 04-23-2020, 12:10 PM
N941WR's Avatar
No, I read an article that says if the main beam is "work hardened" by dropping it, the beam flexes at a different rate, throwing off the reading, regardless of zeroing the pointer bar. Sorry, I couldn't find that article.
I had no idea that was even possible. Just shows you learn something new every day.
(I wish I could buy a split beam torque wrench with a ratchet head! I've never seen such a thing.)
Bill R.
SC86 - Easley, SC
Old 04-23-2020, 01:23 PM
This ..... https://www.harborfreight.com/12-in-...ter-63917.html is very accurate and consistent that I use it to check all of my torque wrenches.
Old 04-23-2020, 02:36 PM
swordtail swordtail is offline
That's the one to own! Electronic wrenches are accurate and repeatable. Your beam type wrenches accuracy is 10-20%, HF is 1-2%. So which one would you use?
Old 04-23-2020, 06:07 PM
FinnFlyer FinnFlyer is online now
Worked fine at first, but now my HF eats batteries like there's no tomorrow.
I guess for occasional use one could hook up an external battery.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
