Old 04-21-2020, 11:04 AM
JDBoston JDBoston is offline
Default Shelf life of Sherman Williams Primer
I have restarted work on my 14A, and know that Sherman Williams mentions a three year shelf life for their wash primer. Has anyone had success using older primer perhaps 4-5 years old or should I do something else? SEM Rattle can is the other option, but I am in the process of dimpling all the skins for the tailcone so I have quite a bit of surface area to deal with.
Jeff
RV-14A
Status: Wings complete(ish), Working on: Empennage. Fuselage kit on order
http://vans14a.blogspot.com/
Old 04-21-2020, 01:40 PM
Dean Pichon Dean Pichon is offline
If your paint is only a year or two past its expiration date, I would mix up a small batch to confirm that it cures properly. If the containers were well sealed and the contents appear ok, you should have no problem. If you are still concerned, you could do a tape adhesion test (ASTM D3359 or similar) to confirm that it sticks well to the substrate (aluminum?).
Good luck,
Dean
Old 04-21-2020, 03:38 PM
wirejock's Avatar
wirejock wirejock is offline
Default P60G2
Sure hope so. I sprayed lots of parts past the date. Last one needed to be stripped to get bare metal. Took me all day to get it off!
I agree with Dean. Test of scrap to be sure.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 04-22-2020, 03:52 AM
goatflieg's Avatar
goatflieg goatflieg is offline
I've already thrown away $$$$ in expired S-W paint. I was a fool to stock up early, and I've still got some wash primer and primer that I'll have to test shoot. Not taking chances on the top coats; already replaced some stock.
Martin J Filiatrault
Clarkston, MI
RV-8 #83507 - currently working on finishing & firewall forward.
N657AR reserved
Builder websites:
http://goatflieg.blogspot.com/
http://www.mykitlog.com/goatflieg/
YouTube Channel:
https://www.youtube.com/user/goatflieg
Dues paid for 2020... extra payment included for psychological therapeutic services rendered.
_______________________
Have you ever gotten the feeling you were smarter than you could ever prove?
Old 04-22-2020, 10:02 AM
wirejock's Avatar
Default Kirker
I've moved to Kirker paints. If I build another, it will be my paint for interior and exterior.
Enduro Prime is an epoxy primer. Tough. Comes in white, gray and black. Perfect for dual use. Primer and interior color in one. Easy to spray and touch up. Cheap.
I'm equally impressed with their UltraGlo Single Stage. Beautiful finish coat.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-22-2020, 10:04 AM
Default Interior primer
Just to be clear to people (and thanks for the suggestions so far) this is for the interior, not priming to paint. I am going to see if I can use what I have because I have been happy with the wash primer so far as well as the SEM rattle cans at least for the use I have.
Jeff
RV-14A
Old 04-22-2020, 11:34 AM
wirejock's Avatar
Default Jet Flex SB
Ok. Let's try again
I sprayed interior parts P60G2 then Jet Flex SB within a 30 minute window. I would still use P60G2 on the airframe. However, I would use Kirker Enduro Prime as an interior paint with no primer if I did it again. Colors are virtually the same. Flat gray and black. I could achieve the same look with one paint, save weight, cost and have an epoxy interior finish. Quarts are about 1/2 the cost as SW paint.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-22-2020, 11:36 AM
Originally Posted by wirejock View Post
Ok. Let's try again
Now I understand what you are saying. Thanks!
Jeff
RV-14A
