  #11
Old 04-21-2020, 07:50 AM
Jetmart Jetmart is offline
There is actually a small difference in price. The left being about $5 cheaper.
https://www.aircraftspruce.com/catal..._antenna-1.php
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 04-21-2020, 07:52 AM
N941WR's Avatar
N941WR N941WR is offline
My Archer antenna is in the left wingtip, or will be when I install it.
Both Dynon ADHRS are one bulkhead behind the baggage compartment bulkhead.
I was worried about the cable running by the roll servo in the right wing, which is why I opted for the left wing for the Archer antenna. I don't know if this will be an issue but no sense in risking it.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-21-2020, 07:58 AM
Desert Rat Desert Rat is offline
Originally Posted by N941WR View Post
Mine is in the left wingtip, or will be when I install it.
I was worried about the cable running by the roll servo in the right wing, which is why I opted for the left wing.
CanBus seems like pure FM to me, but I thought that it would be a good thing to have it in the same wing as the servo for wiring simplicity. Am I wrong?
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 04-21-2020, 08:14 AM
N941WR's Avatar
The CAN bus had nothing to do with my decision.
For me, installing the two ADHRS was a retrofit from a D100. It was a pain working the fuselage but has worked out well. I installed a Dynon hub next to the pitch servo and plugged everything in there and bought one wire bundle forward. Pretty much the same as installing it in the wing tip.
There are a couple of reasons I didn't install the ADHRS in the wings; I remove my wing tips every year, I didn't want to risk damaging them, and I figured if I get hangar or ramp rash, it would be a wingtip that gets damaged. Better to have those delicate pieces of electronics in the fuselage.
Just my feeling.
Yes, it was a pain installing them after the fact as I had to drill up the floor and then work in the tailcone while sitting in the baggage compartment but now that it is done, I'm very happy with it.
The Archer antenna is being added in the next month or two and not at the same time as the ADHARS so it wasn't a mater of being "easier". I did run conduit down both wings, so it is a simple matter of pulling the cable down the wing.
Bill R.
SC86 - Easley, SC
Old 04-21-2020, 08:22 AM
rswalden's Avatar
rswalden rswalden is offline
Originally Posted by emsvitil View Post
Put one in each wingtip so you can land centerline........
Ha! But that never happens.
Actually I installed an Archer antenna in both wingtips. My Garmin 650 uses the left wing. And since my SL-30 radio has ILS capability, I have that going to the right wing. May as well. Still doesn't help my landings....
Bob Walden (Waldo), CFII-ASMEL, Commercial Glider
KFFC "Falcon RV Squadron" Peachtree City, GA
RV-7A Tip-Up, IO-390, 700+ Hours
EAA/AOPA/Vans Air Force 2020 Supporter
Old 04-21-2020, 08:24 AM
N941WR's Avatar
Do you notice much difference between the two? Granted, the different receivers probably have a bigger impact than the antennas being separated by the width of your wingspan.
Bill R.
SC86 - Easley, SC
Old 04-21-2020, 11:53 AM
rswalden's Avatar
Bill,
Honestly I don't see much difference in signal strength. But, now that I can shoot LPV RNAV autopilot coupled approaches to 200'... I rarely use the ILS and VOR except for training.
Old 04-21-2020, 12:03 PM
terrye terrye is offline
Terrye-
Any problems in that location? Seems like there's a lot of steel back there, especially since I'm building a taildragger.
Not installed yet, still working on firewall forward and instrument panel.
Terry Edwards
RV-9A (Fuselage)
2020/2021 VAF Contribution Sent
