04-14-2020, 10:43 AM
Replacing Stripped Nutplates
So it seams an overzealous individual with an impact driver took out some nut plates in my seat pans.
I want to replace any stripped nutplates but not sure I need to invest in a squeezer.
I saw some recommendations using "oops rivet" sized blind rivets...are there any other recommendations?
Tim
Tim Holmes
Appleton, WI
ATP, CFI/II/MEI, LSRM
RV-9A N904DC
2019/2020 Dues Paid
04-14-2020, 10:54 AM
An inexpensive squeezer to have is a good thing and I might even consider it an essential tool for an RV owner. If that is not a possibility, smaller pull rivets are available and acceptable.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
04-14-2020, 11:02 AM
I have used MK319-BS rivets with success.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
04-14-2020, 11:10 AM
You can use an A rivet in place of an AD. The A is softer and easy to set with no effect on the nutplate or it's use. You can set them with with altered ( smooth down the grip teeth or cover with a piece of aluminum) pair of vise grips. Or you can use these.... https://www.homedepot.com/p/KNIPEX-1...-SBA/206162134
The vise grips are a lot cheaper.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
04-14-2020, 12:00 PM
+1 on the mk319 rivet. Drill out the old alumninum rivet and install the new nutplate using the pull rivets
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
04-14-2020, 12:05 PM
Originally Posted by gasman
+1 vote for the Nipex parallel jaw pliers. I use these to squeeze both A and AD -3 rivets often.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
04-14-2020, 12:10 PM
Ask your local EAA chapter for a loaner tool??
04-14-2020, 01:19 PM
This is a great squeezer for $135. You will use it extensively owning and maintaining your plane. It is all you need since you are not building : https://www.aircraftspruce.com/catal...clickkey=26925
04-14-2020, 01:26 PM
CCR264SS3-3 3/32 CS blind rivets
I have a small bag I picked up from Airparts at SnF. They come in handy once in a while.
https://www.airpartsinc.com/712_CHERRY_RIVET_CCR.htm
Mike W
Venice, FL
N164WM
04-14-2020, 02:14 PM
been here awhile
Originally Posted by pa38112
I built my RV-6 with that squeezer......highly recommended as a reasonably-priced addition to every non-builder RVer's toolbox..
