04-11-2020, 07:26 PM
3/4 turn method for oil filters
What's the 3/4 turn method for oil filter torque?
I assume it is:
- use a marker to label 90deg / 180 deg / 270 deg / 360 locations (and maybe in between)
- after screwing on the oil filter, from the moment the gasket touches the body, using the markings as reference, ensure it's been turned an additional 270 degrees?
- safety wire.
04-11-2020, 08:06 PM
Spin on the filter 'til the gasket touches then turn 3/4 turn more. Really doesn't matter if it is 269 or 271 degrees, don't get anal.
04-11-2020, 08:07 PM
Oil Filter
You can?t go wrong with the official guidance, 18 to 20 ft lbs is the torque for the Champion brand. They also specify Dow Corning DC-4 as a lubricant on the rubber gasket before install. The 3/4 turn method with some engine oil on the gasket works well enough if you know what tight enough, but not too tight feels like.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
04-12-2020, 02:05 AM
The 3/4 is bush style... better follow the manufacturer?s instructions, usually a specified torque.
Also beware that some, Tempest as an example, are installed dry no oil.
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
04-12-2020, 03:45 AM
If you don't have a fancy torque wrench, "Bush Style" works pretty good, and has done so for a few decades. In fact, some filters have the "3/4 turn" instructions included. Could that be construed as "Manufacturer's Data?"
Some things require more precision than others.
Just my Dos Centavos.............
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
04-12-2020, 04:13 AM
I would hope everyone that does ANY maintenance on their RV has access to a torque wrench. Does not need to be fancy, but it is a must for aviation.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
04-12-2020, 07:51 AM
Torque wrench
Couldn't agree more that a torque wrench, or two or three torque wrenches, are needed for construction and maintenance of aircraft.
However, most standard torque wrenches and their required sockets or crowfoot extensions don't fit easily on the oil filters installed on most RV aircraft. Hence the existence of "fancy" purpose-built oil filter torque wrenches.
I borrowed a friend's oil filter torque wrench, and at the same time, I marked the filter for a 3/4 turn.
Result was withing a few degrees of the 270 degrees required.
Again, sometimes precision is required. Sometimes it's not. I would submit that oil filter torque is not a close-tolerance issue.
YMMV, as always.
RV-6, RV-6A, T-6G
ATP, CFII, A&P
Reason: Add comment.
04-12-2020, 07:55 AM
How do you put a torque wrench on a WIX oil filter?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
04-12-2020, 07:56 AM
Just did the oil filter change gig yesterday. Champion. Hitting resistance and then going 3/4 turn is not enough torque IMHO. I torqued to that standard, then torqued further to 18 ft/lbs and was really surprised to see how much more was required to get to spec.
Jeff Orear
RV6A N782P
Peshtigo, WI
04-12-2020, 08:26 AM
Exactly!!
The filters I have used for 15+ years do not require a torque setting - only +3/4 turn after the o ring touches the pad. I put silicon goo on the o ring just in case. Never had a car/mower/tractor/truck/farm gas/diesel tank or airplane engine filter come loose since I have done oil changes (60+ years) - why would an aircraft use be any different? My 2 cents, anyway.
I will admit to having some troublems when getting the filters to come loose - that 3/4 turn really does the trick, but sometimes you will need a helpful tool to get ?em off. Filter wrenches might be required for removal - 3/4 turn is all that is needed for the ON process.
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
