Old 04-11-2020, 01:01 PM
Mark Browning Mark Browning is offline
Default 3GX LRU layout
Hello
I am planning my Avionics sub panel lay out for the Garmin 3GX LRUS
Has anyone got any pictures of the sub panel to how they positioned the the LRUS etc.
I need to plan the wiring harness
thanks
Old 04-11-2020, 02:39 PM
bkervaski's Avatar
bkervaski bkervaski is online now
Are you installing the forward access panels that Vans just released? Those really open up some options.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-11-2020, 05:21 PM
Default Yes
Yes, those panels make a huge difference!
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 04-11-2020, 05:51 PM
RonS RonS is offline
You can check my last few blog posts... I'm in the process of wiring stuff up now so there are a number of relevant pics. https://ronslosberg.com/2020/04/11/f...29-and-gad-25/
You can see what the panel looks like here...
https://ronslosberg.com/2020/01/04/f...ting-avionics/
Ron Slosberg
Roswell, GA
RV-14A N3318S -- Flying
Build Log: https://ronslosberg.com
Old 04-12-2020, 02:39 AM
Yes definitely, i wish i had had something like this when i built my 7
The 14 is having them
Old 04-13-2020, 05:35 AM
Thanks Ron appreciate the Links... although looking through i cannot see where you installed the GMU11 and the GSU25
Old 04-13-2020, 11:25 AM
JTJones's Avatar
JTJones JTJones is offline
Jeffrey T Jones
RV-14 N588TJ Completed
First Flight July 10, 2018
Flight testing completed August 14, 2018
2020 VAF dues paid plus beer money😜
Old 04-13-2020, 01:05 PM
Thanks Jeffrey
much appreciated
Old 04-15-2020, 08:31 PM
The GMU 11 is mounted in the left wing. I used Van's ADAHRS mount which was intended for the GMU 22. But with a few mods it worked out well. https://ronslosberg.com/2019/07/29/s...-bottom-skins/
The wiring in the Van's Harness is set up for the GMU 22 as well. It does not accommodate the can bus connection, so I had to repurpose some of the wires from the tail to extend the can bus into the left wing and then from there to the panel. You can see that in this post... https://ronslosberg.com/2020/01/11/b...ss-section-55/
You can also check the can bus tab on my wiring sheet to see the order of the can bus connections. https://docs.google.com/spreadsheets...it?usp=sharing
The GSU 25 mounts to the back of the GDU 460. I haven't wired that yet.
Ron Slosberg
Roswell, GA
Old 04-16-2020, 06:32 AM
Stockmanreef Stockmanreef is offline
send me a PM and I will send you pictures of how my panel and sub panel is laid out. I have almost everything on the left side.
you can see a picture of my main panel on the Stein Air website. 73XP--it has a carbon fiber panel.
Maybe I will post to my FB page.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
