Old 01-30-2020, 09:12 AM
SuperCubDriver SuperCubDriver is offline
I am wondering why you are installing two boost pumps. Do they run together or just one at a time? Is there a check valve on each pump?
My Andair boost pump just failed, of course away from home. After seven years and may be 30 hours run time. I wished to had a setup like yours!
RV-7 flying, IO-375 w. P-Mags, 200RV Prop
RV-8 flying, IO-375, P-Mags, 74RV Prop
Old 01-30-2020, 09:23 AM
kentlik's Avatar
kentlik kentlik is offline
Hey!
I am running or will be running SDS EFI, which runs on an electric fuel pump. The second is the backup pump and you typically run one pump at a time. The manifold setup is a nice clean installation they offer.
There will be a downstream fuel pressure regulator that is not pictured. It is a loop circulation system, so there is a return line to the fuel tanks.
These SDS systems have a great track record and are very clean looking to boot!
Not familiar with the specifics of your system but I am guessing you could integrate a backup...or maybe not...
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 01-30-2020, 04:49 PM
BSwayze's Avatar
BSwayze BSwayze is offline
Hey Kent! Looking good!
Did you ever get the rest of those rivets done on your wing? I don't know what kind of arms can reach in there, but I hope you found a way. Keep up the progress!
Bruce Swayze
RV-7A Standard Build
http://www.BrucesRV7A.com
Old 01-30-2020, 08:12 PM
kentlik's Avatar
Not yet! It is doable but I need to get some time with serious concentration and vitality!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-07-2020, 12:55 PM
kentlik's Avatar
Had these to post for some time:
[IMG]IMAG1119 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1124 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1131 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1151 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1161 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1167 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1205 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1209 by Kent Luttrell, on Flickr[/IMG]
[IMG]IMAG1217 by Kent Luttrell, on Flickr[/IMG]
Finally got the wing sorted out. Took a way long time with my hobbit arms, but had some help with part of it, James Jula, thanks!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-08-2020, 11:30 AM
FuturPilot's Avatar
FuturPilot FuturPilot is offline
Default switches
On the electrical side with regard to the landing/wig wag switch, what is used to make likes "wig wag" vs both on?
RV7 Wing/Tail purchased, Fuselage/Finish arrived, building.
RV-4 Emp started, sold
RV-7 Emp, sold
USAF MSgt Ret
Dan Lade
Old 04-08-2020, 01:24 PM
kentlik's Avatar
Well, I was going to add a "wig/wag" module to initiate that feature. As it turns out with the "ACM" component I am electing to use in the plane from Advanced Flight has a "wig/wag" function so I will not have that type of switch. I don't believe. That is an on/off/on switch. I haven't dug back into that after deciding to go with the ACM.
I am still in the learning stages of a lot of this electrical systems final design.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-25-2020, 03:53 PM
kentlik's Avatar
Fuel selector cover
[IMG]template cover fuel by Kent Luttrell, on Flickr[/IMG]
[IMG]fuel valve cover by Kent Luttrell, on Flickr[/IMG]
I had to make a custom cover to enclose the lines for the SDS setup.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-14-2020, 06:37 PM
kentlik's Avatar
I got the left tank retrofitted with the return line and sealed up.
IMAG1248 by Kent Luttrell, on Flickr
tank access by Kent Luttrell, on Flickr
IMAG1246 by Kent Luttrell, on Flickr
A little messy but I think the function is there but only testing will tell. I just noticed that the "Z" bracket in the photo is wrong. Drilled for plate nuts that are not indicated. Replace or fill holes with rivets? Hhmmm
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 05-14-2020, 08:22 PM
jcarne's Avatar
jcarne jcarne is offline
Heck ya dude!
I think replacing that Z-bracket would be a beotch! Okay, not that bad but I wouldn't want to play around with more proseal if it wasn't necessary. I think I would fill the holes and move on. With this one being on the inboard end I might also send an email to Van's but I'm betting they would say the same. Never know though I guess.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
