Old 04-02-2020, 03:15 PM
laserman laserman is offline
Default Power Setting Tables For XIO-360MIB?
So All...... I have been looking around..
But have not been able to find... They gotta be out there...
The...
?Engine Power Setting Tables.. The typical ?Percentage Power with MP-RPM-Altitude? tables? for the VANS supplied XIO-360MIB.
Either a jpg or docx format so I can pull them into my POH.
Can anyone direct to or supply ..
Many thanks
Al
Al Karpinski
2020 - RV8 N489RV ..( aka “LipStick”) - 20 hours into Phase 1 fun..
2016 182T N522CS
Home Airport B16.
2020 Dues Paid.
Build Log Link:
https://photos.app.goo.gl/XpkYCodwBCjAqeMb7
Smoke System Installation Link:
https://photos.app.goo.gl/UcwHherTSJTyJiuH8
Old 04-02-2020, 05:17 PM
KatanaPilot KatanaPilot is offline
The...
Many thanks
Al
I have a couple of charts for an IO-360-M1A that will probably work just fine for you. Send me your email and I'll send them to you.
krea dot ellis at gmail dot come
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 04-02-2020, 05:23 PM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
It is really dead simple.
Create your own based on the following. And remember this, you do not need to be within a few % to be useful. Despite what some people will tell you.
When operating Rich of Peak EGT.
HP = Max rated x (MP/29.9) x (RPM/max RPM)
Example at say 8000' roughly WOT/2400 RPM and ROP, (22/30) x (24/27) = 65% of rated power
When LOP, with a standard compression ratio 8.5-8.7 : 1, take Fuel flow (USGPH) x 14.9 /rated HP
Example as above, WOT / 2400 RPM / 7.9GPH (and LOP)
14.9 x 7.9 = 118HP divided by 180 equals 65% power.
You would typically be doing this at 24.4" or around 5500', which if you were ROP would be 72%.
Rough numbers are good enough. In fact rather than 14.9 just use 15.
If you or anyone else tries to make it more complicated, you need to rethink what you are doing.
Hope that helps.
David Brown
Old 04-03-2020, 05:28 AM
Default Thanks
Thanks.. I will use the simple equation method to generate the charts ..
They will look very impressive.. Even if they are never used 🤓
Al
Al Karpinski
2016 182T N522CS
Home Airport B16.
2020 Dues Paid.
Build Log Link:
Old 04-03-2020, 07:43 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
My numbers for my RV-7A, XIO360-M1B, 74" Hartzell Blended Airfoil CS Prop, dual Pmags:
SPEED! Cruise Performance at 8,500’ MSL,
With LEANEST Cylinder EGT 100 degrees RICH of Peak:
% Power MAP RPM Fuel Flow KIAS / KTAS
75% 22.9” 2600 11.5 GPH 148 / 168
70% 22.3” 2500 10.5 GPH 143 / 163
65% 21.6” 2400 9.7 GPH 138 / 157
ECONOMY! Cruise Performance at 8,500’ MSL,
With RICHEST Cylinder EGT 30 degrees LEAN of Peak:
71% 22.9” 2600 8.6 GPH 144 / 165
70% 22.9” 2500 8.5 GPH 143 / 163
65% 22.6” 2400 7.8 GPH 138 / 157
60% 21.0” 2400 7.3 GPH 132 / 150
Data Source: Dynon Skyview Classic system numbers
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 04-03-2020, 04:08 PM
Bob Redman Bob Redman is offline
Default SAME SAME
G'day Scroll,
thanks for posting.
Similar speeds, fuel flow, configuration.
My numbers observed on Classic Skyview within normal scatter.
RV-7, Aerosport IO-360 M1, 2 x PMag (25 BTDC, but retarded 1 notch), BA Hartzell 72".
Regards,
Bob Redman
Newcastle NSW Australia
RV-7
Financial until 2029
Old 04-06-2020, 07:15 AM
PhatRV PhatRV is offline
Hope that helps.
Thanks for the information. I never learned this in ground school.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
Old 04-06-2020, 01:55 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Kitplanes article
Kevin Horton wrote a great article about this exact subject in Kitplanes here:
https://www.kitplanes.com/determining-engine-power/
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 04-06-2020, 05:46 PM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
The...
Many thanks
Al
I think this is what you are looking for. It is a PITA since it attempts to amalgamate information for all IO-360 models (apart from the -M1A for some bizarre reason)
https://www.lycoming.com/sites/defau...2060297-12.pdf
Ed Fleming
RV-7- Nearly there!
Harare, Zimbabwe
Old 04-07-2020, 05:37 AM
Capt Capt is offline
Some interesting figures there. I kinda use the 'kiss' method. Just fly my 8 and enjoy the ride looking after my engine at the same time with fuel WOT/2400 @8500' 33lph yields 153 kts IAS. I'm old school ROP, 40 years
