04-01-2020, 03:08 PM
Aeromomentum Engine
Hi,
I?ve been checking in on this forum for several years, finally getting close to pulling the trigger on an RV10 kit. (Wife approval + college costs declining = ready for takeoff)
In just gathering thoughts and ideas for my project I came across Aeromomentum Engines. They have a newish 260 hp engine. Wondering if any seasoned builders have looked at this and what your impression might be? I?ll admit I?m no expert but understand this is a 4 cylinder, water cooled, turbocharged, gear driven design which makes it fundamentally different than a tried and true Lycoming etc. How the heck are they offering it at +/- $20k when an IO540 is +/- $50k? Why should I be leary?
Here?s a link to what I saw
https://youtu.be/InfiwXFDUlo
Ken
04-01-2020, 03:26 PM
Because Mark Kettering is a realistic guy.
You won't save $30K, as you'll wind up getting less when you sell someday...probably much more than $30K less, the reality of installing an alt engine in a conventional aircraft.
You should also be prepared for a lot of creative work, before and after first flight. Some find great satisfaction there, and some hate it.
Understand I like alternative engines. That said, I'd call an RV-10 is a poor airframe candidate. The market is (or has been) very strong for nice, conventional RV-10s with good avionics. Why compromise the investment?
Dan Horton
RV-8 SS
Barrett IO-390
04-01-2020, 03:34 PM
question is, do you want to lead the pack and learn what not to do with a new engine? Don?t have any experience with aeromomentum but haven?t heard of one in a -10 yet.
There are a few potential alternate engines that have come up. From diesels, to the PBS turbine, to auto conversions. They can be done but it comes with some potential downsides. Mostly longer build times, more expensive, and possibly more downtime. If your goal is to learn something new or you are a huge engine buff, go for it. If you are trying to save $$?s then it may not work out the best for you.
I?m sure others can comment on auto conversions in general (what I understand the aeromomentum engines to be).
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - Done (for now)
Fuselage - Done (for now)
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
04-01-2020, 03:42 PM
Hi,
Ken
You've already received some good advise, but I'd offer the following:
Just like anyone who's at your stage of a project and asks "Garmin, Dynon, or ??? in my panel", I'd tell you not to worry about that issue until it is time to make THE decision. The offerings and the relative value of the offerings will almost certainly change a few times before you have to write that check.
If you're interested in Aeromomentum, keep an eye on this forum, their user forum, etc. and see how things play out. They may (or may not) remove themselves from your solution set before you need to make a decision.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
04-01-2020, 05:48 PM
All good points, that?s why I like this place. I?m not looking to be that experimental and the investment is certainly a valid consideration. I?m not going to be the one to reinvent the wheel. It?ll be interesting to see if it gains any traction.
Thanks guys. Looking forward to actually getting into the game.
Ken Asson
Park Ridge, IL
Almost starting RV-10
04-01-2020, 06:53 PM
A good friend and rotary engine pioneer, Ed Anderson, once told me, "If you like to fly, put a Lycoming in your RV. If you like to tinker, put an alternative engine in it."
He had over 500 hours on his rotary powered RV and probably more RV glider time than anyone I know. Thankfully all ended with safe landings on runways.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-01-2020, 06:58 PM
I personally have known Mark Kettering for more than 10yrs and if anybody can make this happen, it's him.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
04-01-2020, 07:54 PM
How do the installed weights compare? CG?
Ed
04-02-2020, 08:20 AM
A fully installed IO-540 is about 505 pounds with all accessories, mount and oil.
The AM20T should be about 360 pounds for the same installation, so a lot lighter and is shorter than an IO-540 with CG that may require extra weights to work - however, no one has completed this installation - it's a design number taking into account the prospective accessories and weights.
I spent a considerable amount of time reviewing, talking with Mark and laying out what a complete FWF package would be with a couple propeller options. Do note that a constant speed propeller will need to be electrically controlled; both Airmaster and MT have a package that will work, although I would tip towards the Airmaster as they were more willing to customize the installation for the RV-10.
I think it would be a fun build to install the AM20T on an RV-10, but it does take a considerable amount of time, engineering and effort to install an engine that the kit wasn't originally designed for. My RV-12 is a great airplane with my UL350, but even though it is an aircraft engine, it would have been much easier to go with the original Rotax design - just not as fun, satisfying for me, nor would I have the performance I currently enjoy.
While personally satisfying, your installation will be "swimming upstream" with the VAF crowd and resale may be impacted - of course, your build costs will be much less too, AND you may be building this for yourself, not the next buyer. There are lots of aspects to consider.
In the end, I decided to build an IO-540-X for my 10 as I just wanted to avoid the considerable time and effort it will take to get the AM20T fully vetted, even after the installation is worked out. I would not do something this experimental if it's a family hauler, or your thinking to fly hard IFR - over the mountains, at night.... but it's very doable, just a harder road with little support, especially from the standard builder community.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
04-02-2020, 11:14 AM
What does it use for a PSRU? I didn?t see that on the website.
Tim
