Originally Posted by 74-07
One trip down the rivet path made a believer out of me. I wasn't the builder but if I ever built, I would take the time to really think about getting those floorboards up and do whatever it took to make it easier in the future. Something as small as a cold solder joint on a single PTT switch connector has already cost a full day's work and now, I get to put it all back together!
Its never too late.
And, there is something to be said for putting your mark on your new airplane, doing some building/modifications can make you feel more connected.
Aside from the tedium of installing hundreds of plate nuts, the only tricky part is creating some under support pieces where the control column channel and flap drive pivot blocks bolt down. I might have relieved a few corner spots a tiny bit to make the panels easier to get into position, too.
I wish I had bought one of those hole-drilling guides for the plate nuts. I developed a pretty good system on my own, but I think that would have been faster.
