Old 04-01-2020, 06:48 AM
terrykohler terrykohler is offline
Default Something Other Than Proseal?
I'm in the process of rebuilding an elevator for my RV9A. It's been a while since I've used proseal (for the stiffners and aft wedge), but it's awful pricey. Anyone use something cheaper that will serve as glue and bedding?
Terry, CFI
RV9A N323TP
Old 04-01-2020, 07:14 AM
RV7ForMe RV7ForMe is offline
sikaflex has been working for us with no cracks on rudder and elevator for about 60h of flight time...
VAF dues paid for 2020
RV7-A (N137MX Reserved) - Wings Started...
RV7-A - Rebuild Done - Flying!
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 04-01-2020, 07:19 AM
bkervaski's Avatar
bkervaski bkervaski is online now
You can get a 3.5oz for $17, it should be enough:
https://shop.vansaircraft.com/cgi-bi...roduct=proseal
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-01-2020, 07:26 AM
Default Thanks Bill!
Somehow I was looking at $109.00 on the Van's site. Big miss on my part. Also checking out 3M 2216 (thanks, Larry)
Terry
Old 04-01-2020, 07:48 AM
DGlaeser DGlaeser is offline
Hi Terry,
If I were doing it, I?d use Goop
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 04-01-2020, 08:11 AM
Larco's Avatar
Larco Larco is offline
I would consider asking other builders close to your place for some that they may have left over. Out of date and refrigerated should be fine and it wouldn't surprise me if some local builders would have some and happy to share??
Larry
Old 04-01-2020, 08:18 AM
Mel's Avatar
Mel Mel is offline
I have 3 cans that were delivered with a BD-5 kit, dated 11/1973 that you're welcome to. Although that may be a little too far out of date. And it hasn't been refrigerated in several years.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 04-01-2020, 08:38 AM
Default Thanks Mel
Ever notice that sometimes, just reading a couple of sentences can make you smile.
Terry
Old 04-01-2020, 08:55 AM
jacoby jacoby is offline
Van's now recommends (and sells) the VHB tape for the wedge in section 5 (although kit instructions don't seem to have been updated to match). Won't help you with the stiffeners unfortunately.
I liked using the tape on my -10 rudder and elevators.
If you go with the VHB tape, get it from Van's. DO NOT get it from Amazon. I tried that and it was heat damaged or old and did not work at all.
Old 04-01-2020, 09:19 AM
PhatRV PhatRV is offline
Terry, CFI
RV9A N323TP
I am building the RV8 so it doesn't have the wedge like your RV9. I use the globs of RTV for the stiffner at the trailing edge instead of proseal to remedy vibration cracking. From experience, the Proseal cures a lot slower than RTV so it gives you longer working time.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
