Old 03-28-2020, 06:53 AM
larrys larrys is offline
Default small tube off mechanical fuel pump
Building a 14A with a 390 Lycoming
Would anyone know where the small tube off the mechanical fuel pump goes? Would you have pictures or where I can find it in the plans.
Thanks! Larry
RapidsetBuildings.com (Hangars)
Advertiser
RV-14 tail, QB Fuselage, Finish kit, QB wings and FF kit, Thunderbolt 390, Hartzell C/S Blended Airfoil. Just need to finish... 90% left to go
Grateful to pay dues 20'
Old 03-28-2020, 07:00 AM
Tom023 Tom023 is offline
Larry,
If you are referring to the white translucent tube, it is there as an overflow and indicator if the diaphragm develops a leak. You will see blue fuel stains in it if your pump is leaking. It just goes down in the tunnel behind the nose gear behind the brace that runs across the tunnel opening. Mine exits pretty close to the breather tube opening.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 03-28-2020, 07:30 AM
Default Thanks!!!!
Originally Posted by Tom023 View Post
Larry,
Thanks! I could not find it on the plan, but now I know
Larry
Advertiser
Old 03-28-2020, 10:44 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Thanks! Larry
See section 43: Engine Installation
Pages 43-05, 43-06
Also section 49: Fuel & Oil System
Page 49-18 for attachment with picture.
Step 5 for taildragger or step 6 for -A model.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-28-2020, 11:31 AM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
It drains the very small space between the 2 diaphragms. If either the gasoline side diaphragm or the oil side diaphragm leaks, you will get either gasoline or oil dripping from the drain. Pump keeps pumping.
Dave
M20C
