  #11
Old 03-24-2020, 06:56 AM
Sam Buchanan's Avatar
been here awhile
Originally Posted by Scott Hersha View Post
Sure wish I had a set of plans for this.
Hey.....we build airplanes.....we should be able to figure this out from a couple of photos....give creativity a chance to run free.
Nice tug, and yes, a MIG (with gas bottle) is a great tool for the shop.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-24-2020, 08:23 AM
rocketbob's Avatar
Very nicely done. I am curious if the wheelchair gearboxes and motors could provide enough torque for a much heavier airplane. I have been contemplating building something similar to move the Comanche 260B I just bought.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-24-2020, 08:45 AM
Tomcat RV4 Tomcat RV4 is offline
The other option used is a used garden tractor/riding lawn mower, work very well and watching garage sales/ local adds can usually be $100-150
Tomcat RV4
RV4 gone to RV heaven !building Zenith 701
dues paid and worth every penny
Life is uncertain -Eat desert first !
U F O Member since Dec 2017
Old 03-24-2020, 10:51 AM
Bob - if you do a search through posts here by Troy Branch you'll see he posted a link to his homemade tug, built to move his RV10. It's a similar concept but of course intended for a nose dragger airplane. His design works well, including offering variable speed control.
Personally, I opted to go very heavy duty and purchased an AeroTow tug very similar to the current GetJet model. It's old as the hills but built like an absolute tank. It was intended to move airplanes up to about 8000lbs and looks overbuilt even for that purpose. I love the idea that it gets the nose wheel off the ground, using the weight on the nose wheel to help provide additional traction.
Old 03-24-2020, 08:06 PM
JordanGrant's Avatar
JordanGrant JordanGrant is offline
I've considered trying to write a submission for Kitplanes. Even if I don't do that, I'll try to write down some of the key things once I reach a final configuration, to make it easy to replicate (i.e. dimensions, angles, part sources). As was mentioned, the MIG welder (with gas) makes the structural stuff pretty easy to make.
Jordan Grant
RV-6 N198G
Monthly donation started Mar '20
Old 03-25-2020, 07:54 AM
Snowflake's Avatar
Do you lift the tailwheel off the ground while moving, or does it just pull the tail along with the wheel running on the ground?
Rob Prior
Old 03-25-2020, 08:44 AM
It works either way, actually. It's easier to turn/steer the tug with the tailwheel up, and lifting the tail puts all the weight on the tug wheels, which helps with traction (on a smooth hangar floor, the tug wheel can spin unless you load them up).
Jordan Grant
RV-6 N198G
Old 03-25-2020, 09:12 AM
Video of the tug in action:
https://youtu.be/g7t8pDY0A8U
Jordan Grant
RV-6 N198G
Old 03-25-2020, 09:28 AM
Alchemist Alchemist is offline
Great project, I love wheel chair motors! I built a smart phone version a few years ago.
https://youtu.be/OVl8BZiq0EU
Old 03-30-2020, 03:07 PM
6ato14a 6ato14a is offline
Default Tug attachment
Loved the tug pushing the Citabria
How does it attach to the tailwheel?
Would it work on rv-a model?
Any more pictures?
