03-01-2016, 07:53 PM
49clipper
Yes the standard tube works. I have been using mine now for severals years with no issues. I changed (to the larger tires) since I fly off a grass strip and it just gives me more area on the ground and is about an inch taller tire and about a 1/2" wider if i remember right. But, I had to go to the newer wheel pants when I changed to the larger tires.
RV-6
03-02-2016, 12:31 AM
old post revived
Nice to see this old post come back alive for a bit. I've been using the 380 x 150-5" tires for about 5 years now, really happy with them. Very noticeable improvement on soft dirt, somewhat noticeable improvement on grass. All around a great thing. Yes, I still use the 500 x 5 Michelin AirStop tubes. All good.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
01-30-2019, 09:52 AM
Great thread with very good info for my newly purchased RV-8 and my grass runway, thanks !
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
03-23-2020, 10:42 AM
Did you modify the 5.00x5 wheel pants or are there larger ones available from a builder/manufacturer (who I haven't found...)? Thanks.
David Abrahamson
Reston, VA
RV7, N98DA, TMX-O360, CS, slider
03-23-2020, 11:03 AM
I've been using the 380?150's for 300+ hrs. and they have been superb, especially on unimproved surfaces. I would estimate over 500 landings on the tires with very little wear showing. I used the stock 500x5 tubes and Van's standard pressure recovery wheel pants, and enlarged the openings as necessary. I did need to space the brake disc away from the wheel using a single AN3 washer to provide sufficient caliper/tire clearance. 35 PSI has been a good pressure.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
03-23-2020, 11:43 AM
Hi.
I used standard wheel pants, but I mounted them 1/2" higher with respect to the standard 500x5 tire than shown in the instructions. I did this during the build to gain ground clearance, but also in anticipation of the switch to the bigger tires later -- which I did. Once I put the bigger tires on, my ground clearance is a full inch more than standard. I can use a flat 2x4 as a wheel chock.
When you raise the wheel pant a 1/2", then the brake caliper sticks out through the side of the wheel pant a little bit, so you need to make a cut-out for that. Then I molded fiberglass blister fairings to blend over that. I think there is an old thread with pictures. I have made a few sets of those blister fairings to sell to other people. PM me if interested. $45 a set plus shipping.
And of course, you have to adjust the tire clearance cutout in the wheel pant as well. Don't scrimp here - it is amazing how much the tire deforms laterally on a cross wind landing. you really want to have a thumb width clearance along the sidewalls.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
03-23-2020, 08:30 PM
Jake
03-23-2020, 08:34 PM
Originally Posted by Jpm757
That's a great picture, thank you.
03-24-2020, 10:41 AM
Thanks guys, great info.
David Abrahamson
Reston, VA
03-24-2020, 01:01 PM
another pic
Here's another couple of pics to show the size difference.
