03-17-2020, 09:23 AM
Lane A and B generator failure on 2nd flight
I did my first flight on February 6th. Before that I accumulated 1 hour on the engine in testing, working the brakes and swinging the compass.
After a few weeks of poor weather I planned a second flight three weeks ago. Immediately after starting the engine, both lane lights started blinking. And afterwards Skyviews error read-out showed "generator failure".
I bought a dongle and borrowed a simulator. Today, running the engine with the simulator the error was confirmed. Rotax is looking into it, and I am waiting for their input. But I thought in the mean time I might ask if anybody on the forum has any experience with this. Any suggestions in finding the origin of the error are much appreciated.
Jeroen
Amsterdam
RV-12iS #121073
Flying Feb 6 2020
03-17-2020, 12:22 PM
Can't see any photos!
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
03-17-2020, 12:34 PM
I see them with the Chrome browser but not the Edge browser.
Jon
12iS SLSA
Salt Lake Int'l
03-17-2020, 02:35 PM
Not showing on my Chrome Browser on a Samsung Chromebook.
03-17-2020, 03:23 PM
See if you have any error lights in the Rotax engine fuse box. Look through the clear window on the fuse box cover which is on the left upper firewall under the cowl.
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
03-17-2020, 11:26 PM
I have a ULS, so my comments should be taken with a grain of salt. Wouldn?t you have a negative battery load indication if the generator really went Tango Uniform (technical term😝  ?
03-18-2020, 02:40 AM
Thanks for your suggestions. I understand little of the electrical design of the iS and I am very happy with any input.
Deene, all lights in the fuse box are in the green (with the engine not running).
Rich, you may be right that the generators went south. But if I understand correctly there are at least two of them. So I was hoping that this problem might be caused by a loose connection or cable. But I have no clue where to start looking.
Jeroen
Amsterdam
RV-12iS #121073
Flying Feb 6 2020
03-18-2020, 03:58 AM
I hope the pictures are visible now.
Jeroen
Amsterdam
RV-12iS #121073
Flying Feb 6 2020
03-18-2020, 09:11 AM
Lane a and b
My problems with the wiring connectors on my RV 12 ULS Rotax were numerous. The engine started with the MAGS ? OFF ! Luckly the AC was chocked, over crimped connectors cut the grounding wires, Other pins pulled out with very little pressure. I don't know who is to blame, electrical harness contractors or Rotax. May not be your prob but it was certinally was mine!!! Hope this helps other folks! GL Ben
03-18-2020, 12:28 PM
Red Lights on Both Lanes
I own an RV12-iS ELSA, bought with 17 hours on it last September (all Garmin gear). In November, at run up, one lane light was solid red, and one blinking. Appeared that second generator not active. I taxied back to the ramp, shut down, waited five minutes, and started her up. No issues. Have made about 18 flights since then without a problem.
During the lane check, I may have turned off Lane A, turned it back on, then failed to wait for the red light to extinguish before turning off Lane B. Maybe. Since then I've been careful to not do that. I have no idea if what I did had any impact.
John Leon
Kingwood, TX
RV12-iS, N221TF, #121130, non-builder
