Old 03-05-2020, 02:31 PM
tdavis1198 tdavis1198 is offline
Default Rudder trim suddenly changes on Autopilot
I have the dynon autopilot in my RV-10 and have noticed a problem where the rudder trim changes suddenly when on autopilot. I realize that there are no servo controls to the rudder but it feels like suddenly someone stands on the rudder (i have seen it go both ways, left or right) during cruise.
I have a dynon autopilot.
Any ideas as to what can cause this?
Old 03-05-2020, 02:35 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Yaw damper?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 03-05-2020, 03:21 PM
No yaw damper
Old 03-05-2020, 03:29 PM
rvbuilder2002's Avatar
Check the friction value in your nose wheel fork.
It is probably too loose.
Spiral prop wash moves the nose wheel in flight which changes rudder trim.
Scott McDaniels
Hubbard, Oregon
Old 03-05-2020, 07:01 PM
Sounds logical. Thanks
Old 03-13-2020, 03:22 PM
Chippster1 Chippster1 is offline
I had the exact same problem. It was the breakout force on the nose gear. Tighten it up and the nose gear will not swing left or right due to prop wash. It was very disconcerting to feel the plane yaw uncommanded. Very simple problem to fix
Old 03-13-2020, 05:14 PM
A-Ron A-Ron is offline
I wouldn't just "tighten" it. I would go back to the instructions and follow it. I think it was 26 lbs using a fish scale with the scale attached to a specific point on the castor.
ASEL Commercial/Instrument
N707XP Reserved
RV-10 Empennage- Complete
Wings- 99%
Fuselage-99%
Firewall Forward- Complete
Now Wiring Avionics
Old 07-04-2020, 04:12 PM
catmandu's Avatar
catmandu catmandu is offline
Another search function win! I am going to set proper breakout force on a -10 to fix a wandering ball. Lots easier than installing a rudder trim servo, but there are some nice options I will file away for possible future use.
Never would have thought of this particular fix, thanks VAF!
Mike C.
Sierra Nevada
RV-6A bought flying
