  #51
Old 09-26-2019, 01:05 PM
RV8iator's Avatar
RV8iator RV8iator is offline
Originally Posted by rocketman1988 View Post
Then we'll have to disagree...
I have witnessed the rubber jungle in the 727. In fact, the OE instructor almost had a coronary when the FO swiped the power off at 20-30 feet...
I also have many thousands of hours in the 767 and with the GE engines, you are going to get a hard landing pulling the power at 20-30 feet...and possibly a tail strike.
Enjoy retirement...I'm still working in the mines...
I am. the only problem with being retired is you can never take another vacation..
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 09-26-2019, 02:19 PM
Oh, yes you can. It happens when the wife says, "You're spending too much time at the airport. We need to go away..."
Old 09-26-2019, 02:36 PM
RV8iator's Avatar
Did you miss her?
VAF #818
Old 11-04-2019, 01:49 PM
emsvitil's Avatar
emsvitil emsvitil is offline
Just a thought
For the last 10ft or so.
Have an option for a beep that beeps faster the closer to the ground you get until it's continuous at 0.
Ed
Old 11-04-2019, 04:38 PM
mtnclimber mtnclimber is offline
Default I used ultrasonic backup sensor
That's exactly what I did on my RV8 and it was a really good training aid for 3-pt landings. I used one of the sensors mounted near the tail where it goes to a continuous tone at 3-point attitude. It has worked flawlessly but after 150 hours I find it more of a distraction, especially with the MGL in copilot mode calling out airspeed.
https://www.ebay.com/itm/Ultrasonic-...0AAOSwDuldnqxK
This would be perfect for an amphibian for glassy water landings. It's cheap at $16 on Ebay. Basically when the tone goes solid pull all power with stick full back, and it sticks with no or minimal hop.
I don't use the led display but wired the output from the sensor board to my intercom circuit. Also turn it on with a switch on the flaps, since at high speeds turbulence causes intermittent 'beeps'. I would be happy to post the circuit and pictures if anyone is interested.
I haven't tried 0/0 landings (WITH A SAFETY PILOT !) but it is so precise that I would't hesitate in a emergency situation.
Roger Bloomfield
N51BL at KAEJ (8,000 msl)
Old 11-04-2019, 06:38 PM
MiserBird's Avatar
MiserBird MiserBird is online now
Roger Bloomfield
N51BL at KAEJ (8,000 msl)[/quote]
Please post your circuit and pictures, this sounds real interesting!
Thanks!
Dave McKinnon
KAJR - Cornelia, GA
1975 Cardinal RG N1593H since Mar 1993
1980 RV-3 N3VR Bought flying Sept 2017
Dues current 2020
Old 03-12-2020, 10:14 AM
saja saja is offline
Smile
I just got this Landing Height Controller. Looking forward to give it a try. Anyone who installed it on -6A can suggest or mention where they installed the LIDAR unit? Thanks.
Old 03-13-2020, 07:57 AM
David Carter David Carter is offline
Default Right Wing Root Fairing
I installed it in the right wing root fairing on my 7A. I don't have a picture of the finished installation, but this pic shows approximately where I installed it. I'll try to get an after picture this weekend.
I really like this device, it works as advertised.
David
RV-7A Slider N87BP (bought flying in 2018)
Superior XP-IO-360
AFP Fuel Injection & Dual SDS CPI-2 ignition
KLZU - Lawrenceville, GA
2020 Dues Paid
Old 04-01-2020, 03:56 PM
Default LIDAR in RV-7A wing root fairing
Here's a picture of the sensor mounted in the wing root fairing.
David
Superior XP-IO-360
2020 Dues Paid
Old 04-03-2020, 11:24 AM
Hi David
Many thanks for the posts and pictures, unfortunately we are on lockdown now in the UK so 0 aviation activity for GA I am sad to say.!
