Old 03-13-2020, 05:06 AM
JDA_BTR JDA_BTR is offline
Default Brake and Wheel Upgrades
Am thinking through the brake/wheel options; cost vs performance.
I think this might be good: http://www.groveaircraft.com/rvwheel.html
Any downside? Does it require any wheel pant mods? What gets left off the finish kit?
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
Old 03-13-2020, 06:01 AM
MikeyDale's Avatar
I installed those Grove wheels and brakes on my RV7 5 years ago and they have performed perfectly with no altercations.
Mike Hillger
RV 7 FLYING SINCE 4/2015!
Garden City, Texas
Dues Paid
Old 03-13-2020, 07:04 AM
chaskuss chaskuss is offline
Default Improving the Cleveland Brakes
Grove makes excellent stuff. However, if they are to rich for your blood, you can improve the stock brakes with thicker rotors. Easy to do. See
http://www.vansairforce.com/communit...ghlight=Brakes
The "how to" is on page 2
Charlie
PS When deleting items from a kit, Vans only gives you 75% credit. It you will be deleting a fair $$ amount, better to not order the kit. Contact Vans to get a packing list for the desired kit. Then order what you DO need, ala carte.
Old 03-13-2020, 07:58 AM
Walt's Avatar
Walt Walt is offline
I did the same Grove upgrade about 12 years ago, would do the same if I was building today.
The Grove is a significant step up in quality and stopping power compared to the Matco.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
