03-11-2020, 06:35 PM
How close can switches be?
Thanks to the replies in my previous post, Stein Air had the switches I was looking for. But you know how it goes, one problem solved, another one created. My current panel has the switches 7/8" (0.875") apart, the new switches are 0.833" wide, leaving a very little bit of space.
So, is 0.042" in-between switches enough, or am I looking at redoing my panel?
Steve
03-11-2020, 07:26 PM
How big are your hands?
Consult with Stein, they can give you some guidance.
My flap switch I moved out a little bit because it was too close to my throttle quadrant. Othere switches I spaced subtly further away from others, depending on the function.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-11-2020, 07:37 PM
Steve
You will be ok with 7/8" (.875") center to center spacing. That is how I spaced my switches too. The DPDT are a touch wider than the SPST switches but still work.
Planned spacing:
Physical spacing when mounted. DPDT mag switches and SPST master shown:
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
03-11-2020, 08:30 PM
Cool, Thanks.
Carlos, what program are you using? I did mine with XPanel. https://www.xpanelsoftware.com/
03-11-2020, 08:45 PM
I don't have a dog in this hunt, but something doesn't look right here. In the second picture of post 3 above, it looks like way more than .042 gap between those switches.
Maybe thats an optical illusion or camera angle or something, but is it possible that here's a math error in the original question? Or maybe those aren't the sam switches in post 3?
03-11-2020, 09:55 PM
It is 0.038 between switches
They are 0.875 wide, so the gap is 0.042 = well close enough for govt work...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-11-2020, 10:35 PM
AutoCAD 2013. I use it for work.
Mine are the Carling brand from B&C. Single pole switch bodies measure 1.134”H x .634”W x 1.018”D and double-pole switch bodies measure 1.308”H x .750”W x .887”D. So there is more than the .042 spacing as mentioned in the OP. He says his switch is .833" wide (unspecified type/model) so spacing only gives him .042 spacing. Tight and very little wiggle room but should slide in if they have a smooth side like the Carling type I show.
Carlos in Arizona
03-11-2020, 11:03 PM
Learning here
I am just learning here, but after one is done wiring, and buttoning up the panel for good, do you guys (or gals) normally cover all the exposed metal connections with shrink sleeving or something ?
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
03-12-2020, 04:33 AM
Sunoco has near me
I don?t. You should be ok with a good la
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
03-12-2020, 02:57 PM
Nice
My new switches are also Carling, but after spending way too much time swearing while trying to get Fast-On terminals on/off (and with the "strong encouragement" of my retired USN avionics Sea Daddy) I'm switching over to Carling switches with screw-on terminals.
