  #11
Old 03-10-2020, 07:55 AM
rvanstory's Avatar
rvanstory rvanstory is online now
Default Hinge nut plates
Slightly off topic of your question... One of the best mods (if you haven't already done so) is to add nutplates to the door side hinges. This saves considerable time taking on an off the doors especially if you glass over the hinge pockets for a McMaster Carr door seal.
Randy Vanstory
Flying RV10 - N783V
1st Flight 08/20/2020
Donation Happily Made 2020
Old 03-10-2020, 08:56 AM
RandyAB RandyAB is offline
I second this. It was very easy to do and quite a bit cheaper than the rather expensive product mentioned earlier.
Has anybody fabricated a decent looking cover for the hinge on the cabin top side? I?m thinking about perhaps making a small cover of some sort that will screw into the hinge itself. It would be pretty simple to tap a small #6 drilled hole or two.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
Old 03-10-2020, 09:31 AM
Default Yes
I made stainless covers for the exterior hinge pockets...the hinge was drilled and tapped for two 6-32 screws. I think I used 025 SS for the covers...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 03-10-2020, 04:46 PM
Richard Connell Richard Connell is offline
I made a plate holding 4 floating nutplates.
Then made up a super dry fluffy spheres mix and filled the whole hinge pocket.
Taped and waxed the hinge first.
Once dry, pulled the hinge out and sanded back the fill to the door.
Now the hinge just slides into a perfect slot in the pocket and you bolt in from the outside. You wouldn?t even know there was ever a pocket there.
It has probably added some weight but likely also made the whole area a lot stronger. I toyed with doing epoxy then expanding foam then more epoxy but just went the simpler way.
I haven?t countersunk the door yet. As I?m repeatedly installing and removing I?m just using regular AN bolts.
Just another way.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 03-11-2020, 09:35 AM
I thought that it was you who did that Bob. Do you have a pic of how it turned out?
Randy P.
1st time builder
Reserved:C-GRPY
Old 03-11-2020, 12:58 PM
Default Yes
Yes, I have pictures but won?t get back to my shop until at least the weekend...
Bob
RV-10
297 HP Barrett Hung
Wiring...
Old 03-12-2020, 01:07 AM
oren_rokach oren_rokach is offline
+1 for pictures!!!
Oren Rokach
4X-ODU
RV-10 QB
Cabin top installed, doors completed!
Wings almost done
Blog:
https://4x-odu.blogspot.com/
VAF 2020 dues paid!
Old 03-12-2020, 07:21 AM
rvanstory's Avatar
Here is a builders log with pics of a hinge cover. (Credit to Robin Marks) http://www.painttheweb.com/painttheweb/RV-10/Doors.aspx
Here's a couple of pics of how they did it.
Randy Vanstory
Flying RV10 - N783V
