  #11
Old 03-07-2020, 10:13 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
I had a Sensenich for 200+ hours and it was basically fine, no rain problems. However, as with any fixed pitch prop, going cross country in up- and downdrafts, you're always adjusting the power, adding power in the downdrafts and pulling it back in the updrafts (with the autopilot flying). 2600 RPM limit was for me a so-what, as I never flew that high or wanted to burn more gas.
That said, I now have a Hartzell constant speed and the plane can climb more steeply than I like, so I climb at higher airspeeds. The big advantage of the /cs prop is that it has more drag, power off, so you can slow down more easily, especially on landing rollout.
The RV-9A has a huge c.g. range, so that's basically a non-issue. But go run some numbers on a spreadsheet and see for yourself.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 03-07-2020, 04:27 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Can?t go wrong with a whirlwind GA, Sensenich GA, or Catto two or three blade. With those options, all available with Nickel leading edges, I would not bother with a metal prop.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 03-07-2020, 04:32 PM
MS19087's Avatar
MS19087 MS19087 is offline
Default My experience
Hi Tom. You may recall I had 3 different props on my -9A. When you flew with me I had a WW ground adjustable. I really liked that prop. Great performance and no issues with rain, CG, etc. I started with the metal sensenich and I felt I never got the performance I expected out of that. The WW was much better in my option. I ended up with a WW 151 which was a real game changer but $$. So given a choice id definitely consider the WW GA prop. I only hear great things about Catto but have no experience. Ask Vlad. He put 4000 hrs on his😮
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 03-07-2020, 06:15 PM
Av8torTom's Avatar
Thanks all. I?m leaning strongly towards the WW ground adjustable now
N677AT reserved
Superior XP O-320, 160HP
Old 03-07-2020, 08:06 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Originally Posted by Av8torTom View Post
Another reason for a ground adjustable???
Maybe give you some versatility to find your sweet spot. The more aggressive cruise prop is good for what it is but lacks when the engine has to work harder, creating more heat on climb. Just remember your climbing the hill in 5th gear.
Al Girard, Newport, RI
N339AG
RV-9
Old 03-08-2020, 07:13 AM
Christopher Murphy Christopher Murphy is offline
Default Because
Originally Posted by Steve Melton View Post
why would you consider a prop limited to 2600 RPM?
Because its a very good performing propellor even with the rpm restriction
Because Its vitually maintenance free
Because it might provide a CG that make the airplane more useful
Because it might be less expensive than other options
Because even as a cruise prop it will give excellent climb performance if you climb at correct speed.
I had one on my 160hp RV4 for 600 hours and it was a very good choice for me.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 03-08-2020, 07:40 AM
Steve Melton's Avatar
Cm
got it. thx
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 03-08-2020, 07:59 AM
Not all metal Sensenich propellers recommended for use on Vans airplanes have that 2600 RPM limit. For instance, my O-360 powered RV4 has a Sensenich 72FM prop and doesn?t have that restriction.. In fact none of the 72? metal props have that restriction.
http://www.sensenich.com/wp-content/...1349891787.pdf
They call the 72FM props 72 inch props, but they are actually 71?. Mine is actually a 72FMS9-1-85, which is 85? pitch. My RV4 climbs very well, but at 2700 RPM in level flight, I?m not at full throttle yet - at any breathable altitude. At full throttle in level flight I?ll see about 2900 RPM. I?ve only run it this way to gather data for Nicole at Catto. A new Catto, or Sensenich repitch is in the plans.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
Cincinnati, OH/KHAO
JAN2020
Old 03-08-2020, 08:23 AM
Av8torTom's Avatar
http://www.sensenich.com/wp-content/...1349891787.pdf.
Thanks for that info
N677AT reserved
Old 03-08-2020, 09:32 AM
pa38112 pa38112 is offline
Here is the issue with a 2,600 rpm limited prop: RV9's are intended to be cross country machines. Generally this means higher altitudes to take advantage of fuel efficiencies. Above 8,000 ft you can not get to 75% power and you cant hurt your engine running it at 2,700 rpm, so if you have a prop that can not exceed 2,600 rpm you are giving up almost 4% of your speed.
Secondly, if your prop i pitched so that you can not exceed 2,600 it is putting a tremendous strain on your engine on take-off. You are going to have higher peak pressures VS the same operation with a plane pitched for 2,7000.
http://aprs.fi/N153MC
2004 RV6A Flying
2002 RV6A Flying
1978 PA38-112
