03-04-2020, 11:23 PM
O-360 Engine question
I have come across a Lycoming O-360 Engine that was manufactured 20 years ago but has never been run. Engine still has original desiccant plugs and storage oil in it. My question is what risk is there and what should be done to get the engine ready to run.
Barry Klussman
RV-10 Empennage Kit Builder
KFYG Missouri
03-04-2020, 11:26 PM
What variant is it??
03-04-2020, 11:36 PM
O-360C1C I believe.
Barry Klussman
KFYG Missouri
03-05-2020, 06:16 AM
That is a long time
What part of the country is this engine located? Has it been there the entire time? Has the current owner had the engine this entire time? Even storage oil won't protect a camshaft for 20 years, unless it was replaced every few years and the engine rotated to allow the oil to cover all the internal parts. Odds of that being done are extremely low.
Best to bore scope the cylinders and pull a cylinder [if owner will allow it] to inspect the cam and lifters for rust.
Charlie
03-05-2020, 06:32 AM
For the right price, buy it!
I bought my first engine (O-290d2) that was overhauled in 1959 and put in storage. It has spent its time since overhaul in a garage in Louisiana.
My thinking was that when I opened it up, if it was rusted on the inside, I would sell what parts I could and recoup my money, probably even make some.
As it turned out, it was spotless on the inside. So, I replaced the O-rings, intake gaskets, hoses, etc. and flew it until a prop strike killed it.
Good luck!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-05-2020, 10:33 AM
I'd also buy it for the right price, if it was stored in a low humidity environment It should be good. If you buy it at a core price I'd say it's worth taking the risk, not much to lose knowing you may have to pay for an overhaul.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
03-05-2020, 11:32 AM
Senior Curmudgeon
I bought a similar engine, rebuilt, pickled and sat for 20 years.
Pulled the jugs, all looked good inside.
Luck of the draw ???
See if the owner will let you pull a cyl and peek inside before making a deal.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
03-05-2020, 11:34 AM
Senior Curmudgeon
Pulled the jugs, all looked good inside. New O rings, gaskets and push rod seals and good to go.
Mike Starkey
VAF 909
Rv-10, N210LM.
03-05-2020, 11:38 AM
Looking at the O-360 variants, I'd be sure which mount the crankcase is machined for. Dynofocal is the default for Vans.
O-360-C1A
180 hp (134 kW) at 2700 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1. Same as the A1A except that it has its crankcase machined for conical rubber mount bushings in place of dynafocal mountings.[1][2]
O-360-C1C
180 hp (134 kW) at 2700 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1. Same as the C1A except with Bendix 200 series magnetos.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
