Old 03-04-2020, 10:58 AM
Murf202 Murf202 is offline
Default Position Sensor for Manual Elevator Trim?
I'm looking for a few "real world" methods on how to mount and attach a position sensor to the manual elevator trim for my RV6A. The sensor will be tied to my Garmin G3X touch. I'm full of ideas, but I would love some feed back with actual examples. Thanks
Old 03-04-2020, 11:20 AM
Jpm757 Jpm757 is offline
I would think a Ray Allen POS-12 sensor would work, attached directly to the trim tab.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 03-04-2020, 11:46 AM
fixnflyguy fixnflyguy is offline
I have a Ray Allen sensor set up for my flaps in my -4 that I tied into the bellcrank under the floor via. R/C model pushrod and snap ends. I would think you could do something similar off the manual trim mechanism and locate the sensor nearly anywhere you want. The R/C model pushrods are super smooth, light and can nearly be tied in a knot.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 03-04-2020, 11:57 AM
Sam Buchanan's Avatar
been here awhile
No ideas for a sensor but after you have flown your -6A a few times you won't need a sensor. You will instinctively know about how far out the manual knob needs to extend for takeoff and the RV will tell you when subsequent adjustments have the plane in trim.
I've flown my RV-6 with manual trim for 20 years and never had any need for a sensor.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-04-2020, 12:09 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Expanding on this, you really only need to set the trim with an indicator before takeoff. At all other times, you use trim to minimize stick pressure.
On one of my RVs, forget which one, I would check the elevator trim position as part of the preflight to make sure that it was about right.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 03-04-2020, 12:19 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Neutral mark on trim knob shaft,
I just filed a small notch on the shaft and added a little white paint ---- neutral works good on my plane for takeoff, and a little nose down for cruise ---- I trim pretty far back on landing, unless I have someone else in the plane.
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 03-04-2020, 02:10 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Trim Position
To supplement the information others have shared, here is some general installation information for position sensors to be integrated with the G3X Touch System:
In general, most potentiometer-type resistive position sensors can be used with the G3X system. Typically these sensors take the form of a 0?5kΩ or 0?10kΩ variable resistor. Electric trim motors with integrated position potentiometers do not require separate position sensors.
Each position sensor installation will vary widely according to the aircraft, motion being sensed, and mechanical installation. A standalone position sensor should ideally be mounted such that the full travel of the sensor is just slightly greater than the full travel of the control surface.
If you have any questions as you are integrating the position sensor into the G3X Touch system, please feel free to contact us directly at G3Xpert@Garmin.com.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 03-04-2020, 02:57 PM
Pilotjim77 Pilotjim77 is offline
My takeoff setting is to have spacing about the length of my finger tip between the bottom of the knob and where the cable meets the panel. A little bit of trial and error provided this as the ideal setting.
Jim
Purchased July 2019: RV-6 0320 Whirlwind Ground Adjustable Prop
"We can porpoises?" -- Leo Farnsworth
Old 03-04-2020, 04:37 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Direct visual
I check the manual trim tab position by looking at it back over my shoulder, I know how much deflection to look for. Once in the air you don't need to look at it because you feel it in the stick, as others have said. In this "real world" method, the pilot is the sensor.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
Old 03-04-2020, 04:40 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Two and a half fingers on mine. Done. Don?t over complicate it.
Mike W
Venice, FL
N164WM
