  #11
Old 04-06-2019, 03:49 PM
jamlip jamlip is offline
This answers my question perfectly.
I think overlaying a new panel will help minimize downtime as I can build and test everything out of the aircraft.
Thanks guys!
Old 04-06-2019, 04:06 PM
Dan 57's Avatar
Dan 57 Dan 57 is offline
did 3 of ?em panels on the -4... yeah, technology was moving faster than I was building
Nevertheless, using 2ea AN-3 bolts on each bottom sides had (and still has) the panel removable pretty quick, and useable as a pattern to trace the outline on the new blank...
Good luck on yours!
Life's short... Enjoy!
http://www.aerofun.ch
Old 04-07-2019, 10:03 AM
Lufthans's Avatar
Lufthans Lufthans is offline
And as an FYI: Vans has a Autocad file of a plain panel on their web site (or at least, it used to be on the old site, I'm sure they've found a place for it on their new one as well). This file includes some standard cut-outs for instruments. A few hours of CAD work and maybe $80 of CNC will get you sorted without having to cut one bit yourself :-)
Hans Teijgeler
Hilversum, The Netherlands
Resurrecting an RV-3B
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
Old 03-03-2020, 05:15 PM
Kooshball Kooshball is offline
Originally Posted by jamlip View Post
I am interested in updating the panel of my 1987 RV-4.
To minimise downtime, I was wondering if it would be acceptable to cut-away the existing panel to create a flange of 3/4" or so all the way around, fix anchor nuts to the back, and then attach the new panel over the top with machine screws?
I guess what I'm really asking is - is the panel a structural in an RV-4?
And, is this acceptable practice, or a hokey mess? I feel fairly confident that it will look smart when finished.
How did your project end up? I am in a similar spot where we plan to remove 6 steam gauges in the middle of the panel, install a sport EX and leave all other existing gauges on the sides...trying to figure the best way to get it done.
Old 03-03-2020, 08:50 PM
I just replaced the panel on my RV4. I bought a new blank from Vans ($55), and cut it out with my jig saw (20 minutes), using my old panel as a template. It fit perfectly. Then I marked my new equipment and cut those holes out with my jig saw - maybe 2 hours with the saw and a vixen file. These holes would also have to be made if you made individual panels as you suggest. I mounted nutplates for attaching the EFIS screens and radio rack, and I was done - aside from painting it. All in all, it doesn?t take that long, and is easy to do.
SH
RV6/2001 built/sold 2005
RV4/bought 2016/sold/2017
RV8/2018 built/Sold(sadly)
RV4/bought 2019 Flying
RV6/Used kit purchased 2021 building
Cincinnati, OH/KHAO
JAN2021
