Old 03-01-2020, 07:01 PM
AviatorJ AviatorJ is offline
Good job! Safe flying!
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
Old 03-02-2020, 08:37 AM
kentlik's Avatar
kentlik kentlik is offline
Awesome! Love the paint especially with respect to the window surround!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
Bi-annual financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-02-2020, 08:57 AM
Dorfie Dorfie is offline
Congratulations Eulice. Beautiful plane. Wishing you many hours of pure joy and safe flying!!
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 03-02-2020, 09:28 AM
rongawer rongawer is offline
Congrats! Looks good. Your 3,000 hours gives me hope...
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 03-04-2020, 07:39 AM
ppilotmike's Avatar
Default Well done!
I am envious of your paint job too. Can you tell me more about that? How much (ballpark) would you say you spent and what was your prior experience before painting. I am interested in painting my bird myself, to save some bucks, if it's a reasonable savings. I have no idea what it costs to have an RV-10 professionally painted, so it would also be good to know approximately what you think you saved by doing it yourself. Thanks for the inspiration!
Mike Rettig
VAF Dues Current
Old 03-04-2020, 08:16 AM
lr172 lr172 is offline
Mike,
I painted my 6 and my 10. You are welcome to call me as well to discuss details and cost projections. I spent about $1200 in materials to paint my 10. Never looked at professional cost.
PM me if interested.
Larry
Old 03-04-2020, 10:17 AM
togaflyer togaflyer is offline
Outstanding!
Old 03-04-2020, 01:11 PM
ecurington ecurington is offline
Default Paint Job
Ballpark $3000 including exterior primer. Red was $1000 for a gallon. Paint is Matrix base coat/clear coat automotive paint with a pearl intercoat in the white. You cannot see the pearl in the pics but I think it even looks better in real life.
Very little experience auto painting. Never clear coat.
Painted in my two car garage with a 2x2 frame and plastic extension on the front. I did a fairly elaborate setup to draw filtered air through the personnel door by framing in four box fans at the car door side. I have a few pics but would have to upload them to Flickr if you are interested.
Very important to maintain a clean area and draw the overspray off. Clean the booth by wiping walls and anything else you can, seal everything up, mop the floor and leave it wet, filters in place both intake and exhaust, fans on, then paint
I designed and laid out the design myself with painters tape using rods to get the curves consistent and pleasing. Then traced patterns to do the opposing side matching. To some extent the design is copied from others.
When I first started I was bad at running both the base and the clear. All of that sands out easily. Base coat dries quick and you sand any runs prior to clear. Clear dries overnight and can be sanded the next day. Quite a bit of time cut and buff. The better painter you are, the less time you will need to cut and buff. The idea is to lay down a enough paint or clear to get it to lay out smooth and not orange peel, but not so much that it runs.
Used a Devilbiss Finishline 4 FLG paint gun, amazon $213.80. Recommended by several on this site that have DIY painted.
A lot of prep. I mostly got every imperfection out or filled, primed two coats and sanded to 600 grit.
It is not perfect by any means. Attempted to touch up some of the gray around the windows and it got splotchy. I would like to redo the gray around the rear windows sometime. Overall, I am happy with it and everyone who see's it is impressed.
Eulice Curington
RV-10 N104EW Phase 1
Old 03-05-2020, 02:00 PM
ppilotmike's Avatar
Thanks Larry and Eulice!
Mike Rettig
VAF Dues Current
Old 05-15-2020, 06:21 AM
FlyinTiger FlyinTiger is offline
Question Very nice!
Great looking -10! Can we see how you finished the interior and panel?
AL
RV-7 flying, thank you Richard Heath III
RV-14A tools purchased, tail number undecided
RV-10 planning underway, N717AJ secured
Launching from SC45
