Old 02-11-2020, 07:43 AM
JwWright57 JwWright57 is offline
Default Wheel bearing fun
Man these wheels are really a PIA lol
First i had them assembled incorrectly, valve was pointed towards the inside of the rim. Changed it around and all was good.
Checked the toe/in out with the string and blocks the alignment was perfect, wont need any shims.
Went to put the wheels on and the bolts holding the axles to the gear leg rub against the inside bearing. See picture. I added a third washer on the backside and that pulled the bolt out enough so its not rubbing. Anyone else have this problem?
https://photos.app.goo.gl/tA5uHgqUk1mZpYQd6
Also just noticed the washers under the axel nut are missing. The were supposed to come with the break/tire kit according to the plans. Just one more fing thing to resolve. I'm guessing I'll have to contact Matco for those
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
12IS fuse kit 99% done
Finish kit 95% done
Avionics kit 1% done
Dues paid 2020
Old 02-11-2020, 09:50 AM
Crafting N112DR's Avatar
Crafting N112DR Crafting N112DR is offline
Default gear version?
What version MLG do you have, the old style, or the new Gun Drilled MLG?
___________
David Rohrlick
PPSEL, A&P
RV-12iS Completed
Airworthiness signed off by the FAA 1/23/2020
First Flight on 3/14/2020
Phase I Finished on 5/7/2020
Need:
Paint?
Serial#12-0864
N112DR
https://youtube.com/c/CraftingN112DR
VAF donation made for 2020
Old 02-11-2020, 10:50 AM
I have the latest and greatest. I've been wondering how they ever drilled the gear legs! It seems like magic LOL.....
I checked and didn't see any plan revisions that changed anything.
FYI I received my finish kit late December (ordered Jul 3rd) and nose gear leg last week.
Rv-12 started!
Tail 99% done
Wings 99% done
Finish kit 95% done
Dues paid 2020
Old 02-12-2020, 01:47 AM
Major-Tom's Avatar
Major-Tom Major-Tom is offline
You are the lucky one! I had 1.25 deg and 1.5 deg toe out. It would have taken 4 shims / 28$ each plus oversea shipping. So I made them from T6061... But the gun drilled gear legs are absolutly amazing.
http://contao.savannah-blog.de/files...211_172246.jpg
D-MDYZ ICP Savannah-S built and flying www.savannah-blog.de
D-ERVM RV-12iS #121128, enpennage, wings, fuselage and finish done, engine and MGL avionics in progress www.tomsworld.de
Old 03-01-2020, 01:52 PM
Charlie12 Charlie12 is offline
Default main gear axle nuts don't have washers
You probably have found this answer by now, but in case you haven't: contrary to the drawing in the KAI, the main gear axle nuts for my Matco wheels/axles do not have a separate washer. The nut is machined in such a way that the washer-like shape is incorporated into the nut. Concept similar to a washer-head screw. The Matco drawing that came with the wheel/axle assemblies shows it correctly, no washer.
RV-12 #120768, first flight Sept. 2016
245 hrs as of 2/1/2020
Old 03-01-2020, 04:47 PM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
My RV-12 (2013) wheels have a washer under the nut
PH-BZT
MyKitlog
Old 03-02-2020, 01:51 PM
Thx Charlie. Yes I called Matco and they said the same thing. LOL I also noticed in the instructions from Matco they don't list the washer. I'm so used to following the plans exactly that when something is amiss I automatically assume I did something wrong.
Rv-12 started!
Tail 99% done
Wings 99% done
Finish kit 95% done
Dues paid 2020
