Closed Thread
Old 03-01-2020, 12:31 PM
SPX SPX is offline
Default Reviewing a RV-9A landing accident last week (28Feb2020)
[ed. Lotsa speculation going on in the replies - always happens. Let's hold off per the rules (#2) until the FAA says something (I closed it). Glad they are OK. Thanks. v/r,dr]
On Friday, a RV-9A had a landing accident at MYF, Montgomery Field, in San Diego. I happened to see the airplane on eBay already (!) and dug a bit deeper to see what I could find.
Really, hearing the ATC audio and seeing the FlightAware track makes me sad. One can visualize the chain starting between the ATC audio, and the FlightAware data.
- First attempted landing resulted in a go-around
- Second landing, ATC requested a short approach.
- FlightAware data shows entering the pattern at a groundspeed of 140 knots.
- FlightAware data shows a groundspeed of 111 knots at 200' AGL
For those not familiar with the RV-9A, the normal "over the numbers" speed is somewhere around 55 - 60 knots indicated, depending who you ask, weight, etc.
Out of respect to the pilot, I wanted to stick to facts in this post. I do believe that the pilot is here on VAF, and I also believe that none of us should feel like this type of accident would never happen to us. You just never know.
My thoughts after assembling the bit that I know.
1) Don't let ATC pressure you to do something that you may not be comfortable with (for example, a short approach).
2) If you're too fast on final, go around.. if you're fast on the next attempt, go around again. Keep trying until your speed is correct.
Hopefully this post, and the unhappy ending for the RV and the pilot, will come to mind when one of us is in a situation that a similar accident chain may be starting.
The best news - no injuries, as far as I can tell.
RV-9A, Fallbrook Ca (L18)
Paid, Jan 2020
Old 03-01-2020, 01:06 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Bummer. Glad all are fine. One of the few with a BRS installed.
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 03-01-2020, 01:42 PM
Sam Buchanan's Avatar
been here awhile
Second nose-plant for this aircraft:
http://www.kathrynsreport.com/2019/0...6-2019-at.html
Thankful there were no injuries.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-01-2020, 02:15 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default ok
Tire looks reusable!
Two nose plants same plane. Yikes.
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 03-01-2020, 04:03 PM
PaulvS's Avatar
PaulvS PaulvS is offline
Lucky that it did not flip over. The nosewheel photo shows what appears to be an anti-splat brace installed.
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, working on fuselage
Flying my low-n-slow Aeroprakt A-22 and the aero club's RV-9A while I build
Old 03-01-2020, 05:47 PM
SPX SPX is offline
Interesting to note that this pilot has had two nose gear collapses in the last year, and neither one resulted in a flip over.
Paid, Jan 2020
Old 03-01-2020, 06:04 PM
skylor's Avatar
skylor skylor is offline
Full disclosure: According to the incident report for the April 2019 incident, the collapsed nose gear occurred after "sustained loss of power"
Old 03-01-2020, 06:08 PM
AlexPeterson's Avatar
I sure would like to know the wheel bearing configuration on this plane.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 03-01-2020, 06:14 PM
SPX SPX is offline
Well, since the first report references ?landing fast,? and this second incident has a recorded groundspeed just before landing at 200? AGL of 111 knots, my assumption is that the wheel bearings probably aren?t at play here.
I only have 100?ish hours in the -9A, but I?d say that if I was 200? AGL at 111 knots groundspeed on short final, I?d be very concerned about whether this landing would be safe and successful.
Paid, Jan 2020
Closed Thread
