Old 02-27-2020, 05:12 PM
davesplace davesplace is offline
Default RV 14 props
Prop suggestions for RV 14? 72, or 74 inch, aluminum or composite?
Old 02-27-2020, 05:24 PM
cubdriver cubdriver is offline
Default RV14 Prop
I flew a RV14A with a 74 inch Hartzell. It was awesome. Fast and Smooth.
Jim Potter - Ramona, CA
RV9A Owner- landed it at Osh on yellow dot
Previous Owner of 1940 J3 Cub
Currently Building RV14a
jim.potter@cox.net
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
"There's a big difference between a pilot and an aviator. One is a technician, the other is an artist in love with flight." - Elrey B. Jeppesen
Old 02-27-2020, 05:45 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default Not that simple
Which engine do you have? Here's the basic Hartzell prop sheet from the Van's mothership:
https://shop.vansaircraft.com/cgi-bi...sprop-hartzell
It doesn't hurt to give Van's tech support a call and discuss.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 02-27-2020, 05:49 PM
Jetmart Jetmart is online now
Van's recommends the 74" for the -14A and 72" for the -14 for ground clearance reasons. I was told that there was no appreciable difference in performance however I have no experience with either. I have not decided if I am going 72" or 74" with my -14.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 02-27-2020, 07:13 PM
Stockmanreef Stockmanreef is offline
Van's did not recommend the 74" for my 14a. I was told that there was no performance and it was recommended that I use the 72".
So in the end is probably does not matter.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
Old 02-27-2020, 08:46 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Below is the link to the Van's Hartzell prop site that shows the recommended props for each engine and airframe combo. Note that the 74" and 72" props are recommended for the -14A, and only the 72" prop is recommended for the -14 to ensure adequate ground clearance.
https://www.vansaircraft.com/order-a...er-order-form/
On the general Van's Hartzell prop site they state: "No testing has been done that suggests any performance difference between the 72" and 74" propellers."
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 02-27-2020, 10:05 PM
jrvssgl jrvssgl is offline
Ground clearance is the best option in my opinion. I would doubt performance difference could be measurable.
Old 02-28-2020, 06:18 AM
Reflex Reflex is offline
I've got a MTV-9-B/183-50A (72" MT 3 blade composite) on order from McFarlane Aviation. Dave McFarlane is fantastic to work with. Learned that MT has done some research on the IO-390 and has some recommendations when using a composite prop with that engine.
FYI - McFarlane is now the US distributor or MT props has props in stock and has plans to expand. Also found that they are a supplier to Van's on various items.
I'd give McFarlane a call...costs nothing and you'll get good data.
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
Old 02-28-2020, 07:01 AM
larrys larrys is offline
Default Vans Special at the show
I timed the Lycoming and the prop for ordering at Sun & Fun. Typically Van's will run a "special" And last year to was free shipping for the motor if bought together.
So I went to see Jeff at the Lycoming booth and had him fill in the paperwork, because I wanted 2 PMags and to make sure I had it right. Then I went to the Hartzell booth and id the same.
I feel it was a good move. I am in the middle of assembly now and it seems to be going well so far.
And I did not questions what was needed and went with whatever Van's prescribed.
RapidsetBuildings.com (Hangars)
Advertiser
RV-14 tail, QB Fuselage, Finish kit, QB wings and FF kit, Thunderbolt 390, Hartzell C/S Blended Airfoil. Just need to finish... 90% left to go
Grateful to pay dues 20'
Old 02-28-2020, 07:19 AM
Discus2b Discus2b is offline
Already information and opinions on this you can search. 74 vs 72....74 is the ideal prop but has pilot performance limitations.
R
