Old 02-22-2020, 10:29 AM
avrojockey's Avatar
avrojockey avrojockey is offline
Default A vs B Curve with a Single PMag
Tried calling Emag Air yesterday but it was late on a Friday. Here's my musings for which I need some opining...
I normally want to travel efficiently as possible so I'm usually 55-60% power as LOP as I can run smoothly on a carb. I'm running on a Slick Impulse on the left and a PMag on the right.
At low power settings (pilot or altitude induced) and leaned, the PMag advances the ignition to the point were the Slick Mag is dead weight. With the PMag spark doing all the work this tells me the combustion process is taking longer because of the single flame front. This would lead me to believe a more advanced (B curve) ignition would provide greater efficiency in this condition. However, if I switch to the B curve I would loose some detonation margin and also high-power/low altitude efficiency with the ignition advanced too much.
What are you thoughts regarding combustion delay with a single PMag?
Is the only way to get the best of both A and B curve worlds manually manipulating the advance in real time with EI Commander?
There's some conflicting information regarding the static/base timing of the A and B curves, I've read 20/25 respectively and 26.6/30.8 - Does anyone know what is correct?
This is on a RV-9A - O-320-E2D with 8.5:1 pistons FP prop
Tim Holmes
Appleton, WI
ATP, CFI/II/MEI, LSRM
RV-9A N904DC
2019/2020 Dues Paid
Last edited by avrojockey : 02-22-2020 at 10:58 AM. Reason: Edited to show aircraft info...
Old 02-22-2020, 10:53 AM
Bavafa Bavafa is offline
Not knowing which engine, I can't speak with certainty. However with my IO360 and IO390, I found no real improvement, even high up, with the B curve. After playing with it and burning some fuel during testing, I have the EICommander so I can change the timing easily, mine was left on the A curve.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 02-22-2020, 11:20 AM
scsmith scsmith is offline
You might be surprised how much the Slick with fixed timing is still contributing, even with so much advance on the Pmag side. Even though that spark is late to the party, it still burns off the side that the other flame front may not get to until much later. So it does still result in an increase in chamber pressure at the critical 5--15 degree ATDC point.
Try turning it off to see the difference.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-22-2020, 11:23 AM
lr172 lr172 is offline
The slick is not dead weight and you do have two flame fronts. You can experiment yourself. Turn off the mag in flight. Should see EGTs rise and airspeed drop once the mag stops sparking, more so when LOP, with the engine wanting more advance. Effective timing (i.e. what gets you to peak pressure) is a blended combination of the two different plugs spark advances.
You are seeing the limitations of a pre-packaged, non-adjustable system. You need different timing for different combinations of several different factors, most notable being MAP and mixture.
Old 02-22-2020, 11:40 AM
avrojockey's Avatar
I did this when running LOP under my normal cruise conditions (55-60% power)...there is no drop when going from Both to Pmag only and when I go from Both to the Slick the engine barely runs and I see a 200-300 RPM drop. The lack of an RPM drop on the PMag led me to believe timing is advanced far enough in this situation it's doing all the work. I'll have to look at EGT's again to confirm.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
Old 02-22-2020, 12:43 PM
Toobuilder's Avatar
The Slick is definitely bringing something to the party. Remember that the end game is peak cylinder pressure at the optimum crank angle. How that happens does not matter whether the combustion process is initiated with a magneto, electronic ignition, laser beam, or flint.
PCP is a composite of the two flame fronts in an aircraft engine, and compensating for the significantly retarded magneto contribution is the key to achieving optimum efficiency. The question is if the Pmag A or B curve is appropriate. Maybe yes, maybe no. The only answer is found in a instrumented, altitude compensated dyno room, or in situ testing.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 02-22-2020, 02:38 PM
avrojockey's Avatar
Originally Posted by Toobuilder View Post
The only answer is found in a instrumented, altitude compensated dyno room.
Dang...just sold mine
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
Old 02-27-2020, 09:30 AM
avrojockey's Avatar
Had a lengthy conversation with Brad at EMag Air...He thinks going from A to B will have little effect in cruise but will have a big (negative) effect at takeoff. He said advancing to B curve is too much to do all at once. In fact he said to try the A curve retarded a couple degrees using the clocking method, which falls inline with the recommendations on VAF.
He did say that in LOP economy cruise with Emag advanced out 9-10 degrees the Slick isn't doing much. He cites that the combustion process timing has mostly to do with the initial kernel of flame starting from the ignition source and since the Slick is late to the game (even though the burn rate is 35-40 deg of revs) it's not doing a whole lot. This is confirmed by doing a inflight mag check and running from Both to Emag only, has no drop in RPM.
Tim Holmes
Appleton, WI
RV-9A N904DC
2019/2020 Dues Paid
Old 02-27-2020, 09:58 AM
N941WR's Avatar
N941WR N941WR is offline
The B curve (no jumper) is essentially for an A65 low compression engine.
The A curve (jumper in) works just ok for a 8.5:1 but can be configured for better performance.
See this thread for more details (and check your PM's).
http://www.vansairforce.com/communit...d.php?t=167948
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-08-2020, 11:35 PM
rwtalbot rwtalbot is offline
Best power is ~25* BTDC for most of us. Additional advance will make CHTs hotter and reduce climb/top speed performance. That is why many PMAG users are now running A curve or retarding the timing by 3 teeth on the flywheel.
Richard Talbot
RV-7A
Sydney, Australia
