Old 02-19-2020, 10:27 PM
bob888 bob888 is offline
Why not use tail tie down ring instead of steps?
Old 02-20-2020, 05:40 AM
Electrogunner Electrogunner is offline
Just me, but I would not pull horizonally on the tail tie down. It's really only designed for vertical stress.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
Old 02-20-2020, 10:39 AM
CDN CDN is offline
Default DIY Tug
I made this one out of some emergency light batteries and some electric scooter parts. All of the motor/controller parts were sourced from Amazon.
It has a thumb "throttle" to control the speed. I've been using it for over a year now and it works great.
I think it cost me less than $300 Cdn to build it, including the 1.5" box steel. There are another couple videos on my youtube account that shows some close-up pics.
The last mod was an electric actuator to operate the attach points from a standing position.
https://youtu.be/XbOx4KMyZQs
VAF Donation made Feb 2020
RV-10 C-GNCX Flying and LOVING IT!
Old 02-20-2020, 10:50 AM
rongawer rongawer is offline
What? Where did you get that information? The tie down should be designed to hold about 3,000 pounds force in all external directions - the wind blows in all directions; 3,000 pounds is the strength recommendation for tie-down nylon rope in AC 20-35C.
For the record, I've pulled my Baron into the hangar by the rear tie-down with a fine floor mounted 1/2 ton winch from Harbor Freight ($100 five years ago) many, many times with no effect on the airframe whatsoever. It's average weight was about 4500 pounds sitting on the ramp and my winch pulled it in fine. Do note that the rolling weight, even up a slight ramp, is much less than the sitting weight of the aircraft.
I have a hard time believing that pulling an RV-10 rearward from the tie-down will damage the airframe, but I'll ask Van's to clarify.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 02-20-2020, 11:01 AM
rvbuilder2002's Avatar
I wouldn't have any concern with someone pulling an RV-10 with the tail tie down.
Pulling it using the steps would give me some concern it it was being done on the ends.
Scott McDaniels
Hubbard, Oregon
Old 02-20-2020, 11:02 AM
What? Where did you get that information? The tie down should be designed to hold about 3,000 pounds force in all external directions - the wind blows in all directions.
Like I said JUST ME in my reply. You can pull on whatever and wherever you want on your aircraft as this was my opinion. The rear tie downs on the RV 10 were not designed to be a tow point. What you did on your Barron is irrelevant, well because it's not a RV10. I hope yanking on your rear works out for you in the future. This is all my opinion so I would definitely consult vans first.
RV10 N620RV
IO540 C4B5
Garmin G900X
Old 02-20-2020, 11:08 AM
The rear tie downs on the RV 10 were not designed to be a tow point. .... This is all my opinion so I would definitely consult vans first.
This is the crux of my issue, you're stating the design criteria as a statement of fact and I'm simply wondering what you're basing that on.
But Scott already chimed in and I consider that a reasonable response; I'll go back to sleep now.
Ron Gawer
Old 02-20-2020, 11:11 AM
There we have it officially.
My opinion holds fast that I still wouldn't do it
On another rear tie down question. I use it vertically with a come a long and a anchor in the floor to raise the nose while servicing the nose wheel. Is this an acceptable method?
RV10 N620RV
IO540 C4B5
Garmin G900X
Old 02-20-2020, 11:15 AM
I would say unequivocally YES. You're essentially just tying down the airframe.
If you use regular aircraft jacks, the lifting points are under the wings, but the tail is the hold down and should easily be able to bear the lifting weight of the nose. Incidentally, the same winch I use to pull my aircraft back into the hangar with, I use a tackle pulley on a floor mounted eye hook and pull the tail down in the same manner you describe on a regular basis. Should work wonderfully for you.
Ron Gawer
Old 02-20-2020, 05:44 PM
bpattonsoa bpattonsoa is online now
Default Home built tugs
This videosis are ultimate home built tug and the stable of earlier tugs.
https://youtu.be/5E6MthAqOMw
https://youtu.be/ella7_dpEG8
Version three pulls my -10 around with ease. They are designed with RV wheel pants in mind. All are built around wheelchair motors, R/C car radio and a controller. Total of parts around $500 and a lot of hours
Bruce Patton
Rans S-20 Raven 796S flying since 2019 (slowly)
RV-6A 596S flying since '99 (Sold)
HP-18 5596S flying since '89
RV-10 996S flying since 2014, quick build wing and slow build fues., - dual Skyviews with complete system, two radio and not much else. Interior completely finished with Zolatone. CF plenum. 1624 lbs, FLYING after a 21.5 month build.
