Old 02-19-2020, 06:30 AM
2of5 2of5 is offline
Default Another build sequence question
I anticipate being finished with my tail kit in the next couple of months, and wanted to see if anyone else followed this sequence:
I was considering ordering the SB fuse kit next, very soon given the 10 week lead times, then when that gets close to done ordering the finishing kit. Reason being is that I haven't quite decided on whether or not I will be going QB on the wings. No matter which way, I'll have a complete airplane minus wings and engine up on gear. It's out of the normal order of things, but any drawbacks?
Todd N.
Kingsville, Ontario
http://rv14.ca C-GLCV reserved
RV-14 - #140665 empennage: finishing tailcone, ordering SB fuse soon
RV-7 - #74495 empennage: FS, partly complete
2020 Contributor
Old 02-19-2020, 06:46 AM
Jetmart Jetmart is online now
Hi Todd
I believe the Lycoming warranty starts 2 years after you receive the engine or first engine start.
That may influence your decision on QB wings or not.
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 02-19-2020, 06:49 AM
Desert Rat Desert Rat is offline
The center section carry through typically ships with the wings as a matched set to the spars, even though it's a fuselage assembly.
Don't know if its a problem to order the other way around, but that's one consideration.
Terry Shortt
AGI, CFI, CFII, MEI, A&P, Janitor
RV7 Empennage & Wing done
Fuselage in process
#72651
https://eaabuilderslog.org/?blprojec...t=all&listcat=
Old 02-19-2020, 06:54 AM
Tom023 Tom023 is online now
Not the case with the RV14. The center section is included with the fuselage and not matched to the wings.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 02-19-2020, 07:36 AM
Hi Tom,
That's good to know, thanks.
Todd N.
Kingsville, Ontario
2020 Contributor
Old 02-19-2020, 09:10 AM
Aluminum Aluminum is offline
Make sure you order the W-00026 template with the fuse, you'll need it in a couple of spots. It normally ships in the wing kit.
Dan V
'91 Zodiac flying since 2013
RV-14A in progress
Old 02-19-2020, 09:19 AM
Av8rRob's Avatar
Av8rRob Av8rRob is offline
Yes, my plane is all slow build and I went tail, fuselage, finish, wing. No big deal at all with the -14
Rob Lasater
Rv-14 flying baby, yeah.
Paid Dec 2019
Old 02-19-2020, 07:53 PM
Thanks for the feedback everyone.
Todd N.
Kingsville, Ontario
2020 Contributor
