Old 02-12-2020, 02:06 PM
E. D. Eliot E. D. Eliot is offline
Default Which Flight Simulator to buy?
Seeking the cumulative knowledge of the group. Please advise as to which Flight Simulator I should buy. Want to 'pre fly' my cross country and shorted flights with the FS. Also need to 'fly' my training routes while using modern EFIS in a moderately slow aircraft. I will be training for my PPC in an ELSA. I'm building an RV-12. Thanks in advance.
Building finally
Old 02-12-2020, 04:00 PM
SantosDumont SantosDumont is offline
If you can wait a few months MSFS2020 looks promising. Otherwise today I do this same mission in xPlane 11.
Old 02-12-2020, 08:16 PM
mbauer mbauer is offline
Default X-Plane
For now still on X-Plane 10. Been with X-Plane since beta 9.0, really like it over the others have tried in the past.
Mike
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 02-12-2020, 08:45 PM
flyinhood flyinhood is offline
For those who haven't seen 2020, it looks pretty amazing.
https://www.youtube.com/watch?v=ReDDgFfWlS4
46 Luscombe 8a Rag Wing, Armstrong starter
RV-6, IO-320, Catto, G3X Panel (Thanks Walt!)
Old 02-12-2020, 08:48 PM
JesseS's Avatar
JesseS JesseS is offline
X-Plane 11 is a great sim for doing exactly what you want. I've done the same thing, where I'd fly a route in the sim the night before the actual flight. It helps get familiar the routes, terrain, airports, etc. You can sync your tablet/EFB to the sim as well. I know Foreflight is supported and others. I used Foreflight myself and it works just as if you were actually flying. I've seen many types of EFIS in the sim as well, depending on aircraft. It seems there are so many free and premium aircraft and equipment combinations out there, you should be able to find what you want.
I also second the upcoming Microsoft FS2020. It looks amazing. Having started with FS98 22 years ago when I first started training, it will be fun to see how far its come!
Jesse S.
Gilbert, AZ
7A Empennage - In Progress
JessesRV7A.com
Old 02-12-2020, 09:48 PM
no7rosman no7rosman is offline
Default X-Plane
X-Plane is good. It also has a Vans RV8 that you can purchase.
Old 02-13-2020, 12:31 AM
KRviator's Avatar
KRviator KRviator is offline
FS98? I kicked off with MSFS 4.0, then upgraded to 5.0 and 5.1.
Those were the days, when you could set the headwind to 60 knots and hover, but the instant your mainwheels touched down, your groundspeed went from 0 to 60 instantly!
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 02-13-2020, 07:07 AM
von_flyer von_flyer is offline
Does anyone have experience with Flight Sim X from Steam? I am looking into loading this with the EAA Virtual Flight Academy on our EAA Chapter's flight sim computer. I understand they have a version for Young Eagles etc. that incorporates Aviore the superhero character for EAA.
John von Linsowe
Michigan
RV-7
Cessna 140
Old 02-13-2020, 07:18 AM
Northernliving Northernliving is offline
Can you customize panels in any of these sims to add your equipment?
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 02-13-2020, 07:23 AM
I used one of the early versions of FS on an Apple 2 in 1979/1980. Pretty sure it was actually written in the mid/late 70s.
Brian J.
Boston, MA
