Old 02-11-2020, 10:10 PM
TrickRacer50 TrickRacer50 is offline
Default RV10 f-1032 counter sink mistake
So I goofed and counter sunk the F-1032 longerons in the back. When looking at the picture that says where not to counter-sink I forgot that the longeron starts one hole forward. So the skins didn't get dimpled incorrectly but the longeron got counter sunk (all the holes). I think later they get counter sunk more for screws but I am not sure.
Is this a problem? I could, if really necessary, replace the longerons since im about to rivet the cone.
Sean Mecham
RV-10: VS, Rudder, HS, Elevator, Tailcone - Complete
Prepairing to Order Slow Build Fuselage
Vancouver, WA - Pearson Airport KVUO
Member of FATPNW
Old 02-12-2020, 03:38 AM
cderk's Avatar
cderk cderk is offline
Sean - look at page 10-25... that should give you a pretty good indication of where you will need to countersink based on rivet type. There are a few in the back that don?t get countersunk because of the fiberglass fairing that gets installed there.
Did you countersink the ones that on page 10-25 say leave open for fairing screws?
RV10
http://n688cd.wordpress.com
Old 02-12-2020, 05:57 AM
flion's Avatar
flion flion is online now
You should be Ok. Check page 12-6 for a cross-section of the fairing screws. I'm a bit surprised there is so little grip surface for the screw threads, but the similar holes for my -6A have gotten somewhat easy to turn yet I see no sign of losing a screw between inspections. So, yes, you will drill out for the screws and countersink again later.
EAA Technical Counselor #5357
Old 02-12-2020, 09:54 AM
Thank you!!!
Sean Mecham
Member of FATPNW
Old 02-12-2020, 09:31 PM
Yes, I counter sunk those. The instructions forget to mention that the angle iron (longeron) starts one hole forward. It looks like they will be fine later in the build but I just wanted to double check.
Sean Mecham
Member of FATPNW
