02-09-2020, 09:23 PM
ADS-B position not showing up on Foreflight
I have the Tail Beacon installed. The ADS-B performance reports from several flights show all parameters passing. However, I do not show my ADS-B position information including my N number on Foreflight, only my GPS position. I am not in anonymous mode. Anyone else have this? Am I missing a setting in Foreflight? I am seeing other ADS-B traffic.
Frank
RV-6a KEIK
02-10-2020, 04:22 AM
It?s ok
You should NOT see yourself. I never have. YMMV. EchoUAT Safefly GPS, clean reports, 50 hrs running this way.
Butch
RV6A Purchased N72TX
2020 Dues Paid
02-10-2020, 05:33 AM
If you see your own plane while flying, that is typically called ghosting (I think) and it will drive you crazy because if you have Traffic Alerts On, it will scream at you constantly telling you that you are close to yourself
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
02-10-2020, 10:29 AM
If you have a separate ADSB (Stratux) you can use it to see if it shows, but you should not see yourself in the airplanes ADSB out
N122EF RV7A
S40 Prosser Washington
=VAF Dues paid 2019=
02-10-2020, 10:38 AM
It?s there.
When in the Foreflight map page, press the gear symbol and find connected devices and it will display what you’re transmitting.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
 I just wish I could afford to live the way I do
02-10-2020, 05:48 PM
You also need to ensure that on your iPad under ?Settings? , ?Privacy? that your ?Location Services? is turned on and ?ForeFlight? is set to ?While Using.?
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
02-10-2020, 06:02 PM
That is not accurate, assuming you?re using an ADS-B IN device that provides position data.
The OP hasn?t told us what ADS-B IN device they?re using. The answer to that question will determine how much ADS-B IN diagnostics are available via More > Devices. Stratus and Sentry offer the most, with others offering somewhat less data.
RV-9A, Fallbrook Ca (L18)
Paid, Jan 2020
02-10-2020, 06:51 PM
Not sure on Foreflight but on FlyQ you can block any N number. If you have blocked you own N number then you will not show, which is a good thing.
Philip
RV-6A - 14+ years, 950+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
02-10-2020, 08:20 PM
I have the Sentry GPS/ ADS-B
Frank
RV-6a KEIK
02-10-2020, 08:29 PM
Privacy setting
You also need to ensure that on your iPad under “Settings” , “Privacy” that your “Location Services” is turned on and “ForeFlight” is set to “While Using.”
Why should you have Foreflt set to “while using “? I looked and mine was set to Always. Not sure what the difference is. Also what causes ghosting and how to prevent it? I sometimes get ghosting. I have an EchoUAT getting gps from a GTN650.
RV-6A IO-320 FP sold
RV-7 IO-370 Titan nearing completion
Donated 2018 and continue annually
