  #11
Old 02-09-2020, 05:01 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Does anyone have the part number to order a RV-8 gascolator o-ring from Van's or preferably Aircraft Spruce since I'm about to send in an order?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 02-09-2020, 05:40 PM
Mich48041 Mich48041 is online now
Not sure but educated guess
Van's GAS-3-4-5 GASKET
Aircraft Spruce 05-12242
Joe Gores
RV-12 Flying
Old 02-09-2020, 05:43 PM
Pilot135pd's Avatar
I think that's for the newer engines. I think I just asked in the wrong forum section because I might have a different gascolator than you. Thanks.
Old 03-02-2020, 02:50 PM
Charlie12 Charlie12 is offline
Default lock-open gascolator drain
I bought a lock-open fitting for my gascolator drain because I had one or a couple of other airplanes and liked it. But when I tried to install it on my RV-12 there was interference which kept me from doing so. It was a while ago and I don't recall for sure what the problem was. I think there wasn't enough clearance for the side rods on the fitting to allow turning it to thread it in with the bowl in place, and I didn't want to be stuck with needing to take the bowl off to remove/install it in the future.
RV-12 #120768, first flight Sept. 2016
245 hrs as of 2/1/2020
Old 03-02-2020, 03:05 PM
Pilot135pd's Avatar
How do you clean the screen without taking it apart?
Old 03-02-2020, 03:07 PM
Pilot135pd's Avatar
BTW you were correct, it was that part. Apparently for the past, I don?t remember what he told me years, they?re using the same size gascolator and just changed the outside. Thanks !
Old 03-04-2020, 09:23 AM
Catbird Catbird is offline
If you can't cope with machinery, improve it.
