Old 01-04-2020, 08:30 PM
stonewallhayes stonewallhayes is offline
Default -1 Wing
I bought an already built 2002 Rv-8a. How do I know if it has a -1 wing or not? I read somewhere that the aerobatic limit is 1550 without it.
Old 01-04-2020, 08:58 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Yes, the RV-8/8A has an Aerobatic Gross Weight of 1550 pounds if it does not have the Dash-One wing. 1600 pounds if it has the Dash-One wing.
This is stated in the Van's "RV-8A WEIGHT AND BALANCE DATA - QUICK REFERENCE" sheet linked below.
https://www.vansaircraft.com/wp-cont.../01/RV8Awb.pdf
And see this post about identifying which wing you may have:
http://www.vansairforce.com/communit...50&postcount=2
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 01-20-2020, 06:57 PM
Greg M Greg M is offline
I had the same question in 2004 and asked Van's Aircraft. Scott Risan of Van's stated "Any spar serial # greater than 869 is a -1 spar." I received my RV-8A Quickbuild in 2001 and have spar serial number 962 so I have a -1 spar and aerobatic gross weight of 1,600 lbs.
Old 02-06-2020, 09:35 AM
Saville's Avatar
Saville Saville is offline
Where is this spar serial number located?
I need to determine if I have a -1 wing or not
Thanks!
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 02-06-2020, 10:17 AM
N941WR's Avatar
N941WR N941WR is offline
Is that backwards?
I would think any spar number above 869 would be a -2 wing, but I don't really know?
Scott?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-06-2020, 10:23 AM
N804RV's Avatar
N804RV N804RV is offline
Originally Posted by N941WR View Post
Is that backwards?
Scott?
I'm pretty sure the wing part numbers follow the convention in the rest of the kit. original part has no -1. Modified design of same part has the -1. (ie. W-715, W715-1)
If its not recorded somewhere in the Builder's log, you're quickest way will probably call Van's, I think they'll have a record of it in your customer file.
The serial numbers are vibro etched into the root end of the main spar. I think they are also documented on the wing kit invoice/shipping manifest.
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 02-06-2020, 10:34 AM
Saville's Avatar
Well I have conflicting data regarding what wing is on my -8:
Vans says it was the old 1550 wing design which was bought in 2000.
The logbook says the wing was replaced and/or rebuilt (unclear) and doesn't say when or what was done.
In many cases Vans has all the info you want. But what it cannot track is who did what, with what, and when.
Flying RV-8 N880BC
Old 02-06-2020, 10:41 AM
N804RV's Avatar
Yep, you're right. Given those facts though, does pulling the wing to read the serial number tell you what the builder did to it?
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 02-06-2020, 10:48 AM
Saville's Avatar
Well that's why I was asking where that serial number is recorded on the spar.
What you suggest is that I have to pull the wing to find out. I'd rather not do that if I didn't have to.
Vans also said that the differences between the -0 and the -1 wing include the fact that the RV-8 -1 wing tank and RV-7 tanks are interchangeable. And that the screw hole spacing on the top and bottom long edges of the tanks are different between -0 and -1.
Does anyone who knows whether or not they have a -1 tank on their RV-8 measure the screw hole spacing? I could compare with what I have on my spar flange.
Another option is to buy a -0 (or -1) wing tank skin and see if the holes line up with the spar flange.
Flying RV-8 N880BC
Old 02-06-2020, 10:55 AM
N804RV's Avatar
This is from an old post from CHASKUSS
Yes there are. The main difference is the top spar cap to the main spar assembly. The -1 top cap is 1/4" thicker at the inboard end. Going from memory [an iffy thing for me] I seem to remember that the original wing's top spar cap is 1.25" X 1.25" at the inboard end. The -1 top spar cap is 1.5" X 1.5" at the inboard end.
The top cap on the original wing ends even with the outboard end of the fuel tank. The -1 top cap extends out 1 bay further, into the inboard bay of the leading edge. Because of this, the inboard leading edge rib for the -1 will have a small notch on the back flange area. The ribs for the original wing leading edge are all the same. See photo below. I've circled the inboard end of my top spar cap.
http://www.vansairforce.com/communit...157#post855157
Ken W.
Mount Vernon, WA
2020 VAF Supporter
