Old 12-27-2019, 11:38 PM
N941WR's Avatar
N941WR N941WR is offline
Since you have the SkyView, you will need / want to do the following:
1. Replace the Garmin transponder with Dynon's.
2. Replace your current SkyView GPS antenna.
3. Install the Dynon ADS-B box
4. Add the ADS-B antenna on the bottom of your plane.
5. Wire it together, which is easy.
I did all that and am VERY pleased with the results. Traffic is displayed in the SkyView, airport dots turn red when IFR, you can press and hold the baro button and the SkyView will update the baro setting from the nearest reporting station, and much much more.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 12-28-2019, 07:09 AM
Radioflyer Radioflyer is offline
Originally Posted by BH1166 View Post
Do you have a WAAS GPS source. Must be WAAS. If not, likely effective and best price option is Uavionix EchoUAT. $1400.
Technically, I don't believe this is correct. In a practical sense, it is more correct. I believe there is an official FAA letter that actually interprets the GPS requirements and the older TSO'd GPS receivers, which were not WAAS, do meet the requirements of the law. I believe these were the TSO C129a receivers such as the KLN-89b, etc. At any rate, if you don't have one of these older receivers to act as your GPS position source, then there is no choice but to have an approved WAAS type GPS. (Note, WAAS alone is not sufficient.).
Old 12-28-2019, 07:10 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
"SHOULD" do:
May "WANT" to do:
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 12-28-2019, 11:22 AM
N941WR's Avatar
Originally Posted by GalinHdz View Post
May "WANT" to do:
If you don't so this, you don't get the integration with the SkyView, which is really good and makes the expense worthwhile.
Bill R.
SC86 - Easley, SC
Old 01-10-2020, 08:59 AM
jselvatici's Avatar
jselvatici jselvatici is offline
Default Any ADSB Out Price Drop Already?
I'm wondering if someone already saw any market price change for ADSB Out solutions?
Probably we will need couple months to see price change? (hope for less )
Thank you.
Juliano Selvatici
RV-9A / N349RV
1st Flight on 8/14/2020
O-320 + 3 Blade Catto Prop + Steam Gauges (yes!)
A&P / Private Pilot
RC Pilot ( if that counts )
2019/2020 VAF Contribution Sent
Old 01-12-2020, 02:04 PM
OKAV8r OKAV8r is offline
I would guess prices will remain where they are until Sun n Fun, and then maybe a show special
Old 01-31-2020, 07:26 PM
JackZ JackZ is offline
Rick
I would replace the transponder with the trig tt22,aka the Dynon unit. Make sure it is the higher power unit as the low wattage one is not certified for use in class c airspace.The gps module upgrade for waas is required(I think this is a uvionics module) belly mounted antenna for now. You are good to go for Adsb out 1090 as you want in Canada. For adsb in you can stay with what you have or upgrade whenever.
I use the tt22 and the was gps module with my GRT system and it works great. I think the parts are the same with Dynon but the pin outs are different. The diversity antenna requirements are not final yet and will likely apply over 18000 feet. In Europe the belly mount antenna work great but not in Canada with the same satellites???
Jack
Old 01-31-2020, 08:56 PM
Jermechanic's Avatar
Jermechanic Jermechanic is offline
Default UAvionix TailbeaconX
UAvionix TailbeaconX if you can wait. When these go on sale I think they will be the hot ticket for pilots wanting the ability to fly outside of the USA and be ADSB compliant! Canada and Mexico plan to require 1090 in certain parts of their countries
https://uavionix.com/faq_category/tailbeaconx/
https://uavionix.com/support/tailbeacon-x-support/
https://www.aopa.org/go-fly/aircraft...b-out-required
Jeremy Prpich
C-GJZI RV6 Slider
Home base CYYJ- Victoria Int'l
Old 02-01-2020, 04:53 AM
rleffler's Avatar
rleffler rleffler is offline
I did something very similar in my RV-10 and have absolutely no regrets. The only variables were that I have AFS EFIS and already had a GTN 650.
You?re not going to find any options that are going to be better integrated with your Dynon screens. The remote transponder is one less item on the panel. It gives you 1090ES for compatibility across North America. The 472 gives you both 1090 and 970, in addition to the FAA feed. Having the peer to peer input is really nice in areas where you may be out of line of sight with an ADSB tower.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 02-01-2020, 07:48 PM
TroyBranch's Avatar
TroyBranch TroyBranch is offline
In Canada you will only need the ADSB in class B in 2022. Class A in 2021. That is airspace above 12500 for B and above 18000 for A. Our major airports are class C only so it doesn?t look like it will effect GA much here unless you often fly above 12500 in CVFR or IFR. You need clearance to go above 12499 anyway.
Troy Branch
RV10 Built and Flying Since Feb 2009
950hrs Plus
CC EX-2 Flying
SuperSTOL Built and Sold
RV9 Built and Sold
Avid Aerobat Built and Sold
Dues paid Nov 2019
