Old 01-26-2020, 05:59 AM
Darren S Darren S is offline
Default ***looking to hire Dan H ! ***
Or anyone with similar tank repairing experience.
My old faithful -7, 1500 hrs, 14 years old, painted, has leaking wing tanks that are getting worst.
Paint bubbling on the rear seal rivets started years ago, now finally there?s blue dye streaks coming from the right tank.
I?m looking to hire someone to fix this for me. It?s too big a job for me.
I want to fly the plane somewhere, drop it off, pay cash when the job is done and fly back home.
I?ve tried reaching Paul Beck at Weep No More, in Minnesota. I?ve left 4 messages. Haven?t heard back from him so I?m looking elsewhere.
Dan, if you read this, can you help me out ? Or know of someone who?s willing to do this for me ? I can?t ignore it anymore.
Old 01-26-2020, 06:22 AM
Jetmart Jetmart is offline
There is currently another thread on tank leaks.
http://www.vansairforce.com/communit...d.php?t=179008
Glenn Martin
Windsor, Ontario
1942 Tiger Moth
2017 Waco YMF-5
Kit # 140694
Received RV-14 Empennage Kit October 22, 2019
Started Tail Cone Dec 2019
Received QB Kit April 2020
Finished a mounted Tail Surfaces to Fuselage June 2020
2020 Dues Paid
Old 01-26-2020, 06:46 AM
Whitman Whitman is offline
Dan is awesome if he will do it, but a busy man.
These are your guys. Hollywood and Cheese live and breath rv fuel tanks!
http://hotelwhiskeyaviation.com/
RV-4, #audiaviator
"Poise under pressure is the single most valuable thing you can have as a pilot. Make mistakes, take corrective action as quickly and calmly as possible and press on."
Old 01-26-2020, 08:36 AM
Mark33's Avatar
Mark33 Mark33 is offline
Yep, another thread going on with regards to this same subject. Pull your tanks off and send them to Paul....he?ll fix you right up. www.weepnomorellc.com
Mark H.
RV-7- IO-360, EFII, Whirl Wind C/S, (Built and sold)
RV-4- O-320, Catto three blade, P-Mags (Sold)
RV-8- IO-360, Hartzell C/S (Flying)
RV-7- (Building)
Old 01-26-2020, 08:51 AM
Whitman, thanks for the link. Never heard of these guys. I'll call them on Monday.
I've tried to contact Paul but as I said in the original post, he's not returning messages or emails. I assume he's still in business but if he's on holidays then it would be nice to say so on the answering machine.
I'm looking for someone to take the tanks off, do the work and then put them back on for me.
Old 01-26-2020, 09:00 AM
Had my left tank done there and had the ER tanks added while in the shop. They rock!
RV-4, #audiaviator
Old 01-26-2020, 09:10 AM
DanH's Avatar
DanH DanH is offline
Sorry, but I'm not taking in work right now. Paul Beck, or Hotel Whiskey, or ask Vic.
As I understand Paul's process, he chemically strips all the old sealant.
Dan Horton
RV-8 SS
Barrett IO-390
Old 01-26-2020, 09:56 AM
titanhank's Avatar
titanhank titanhank is offline
I had hotel whiskey fix my right tank. It never stopped leaking. It is coming off next month again and is going to paul at weep no more.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 01-26-2020, 10:04 AM
rocketbob's Avatar
I'm no Dan but last year I fixed a fuel tank leak on a Beech Musketeer with a HF vacuum pump, a sealant gun with a 3ft piece of aluminum tubing attached/bent appropriately, and a cheap inspection camera taped to the end of the tubing. It was fairly deep on the rear of the tank by accessing it thru the opening in-between the spar and rear tank baffle from inside the rear passenger area. Tank removal on this airplane involves de-mating the wing so this was a hail mary pass before drastic measures were taken. It ended up working beautifully. I taped the fuel cap and vent, drawing the vacuum thru the vent line. I "blipped" the pump and watched the skin draw in, and knew I got the leak stopped when the vacuum held.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
