Old 01-23-2020, 04:40 PM
rnewcomb7797 rnewcomb7797 is offline
Default bell crank to aileron pushrod
I'm working on the bellcrank to aileron pushrods (page 23-04). The threaded rod ends do not go into the pushrod end. Is it best to take the rod ends to a debur wheel and reduce the diameter a smidge or take drill bit to enlarge the pushrod end a small amount.
Ron
#140220
RV 14A tail kit done
QB wings in the crate
QB fuselage done
finish kit in progress
Old 01-23-2020, 08:05 PM
these particular ones get riveted in the tube ends with 470 rivets
Ron
#140220
QB fuselage done
Old 01-23-2020, 10:50 PM
Jake14 Jake14 is offline
aren't both those parts steel? or just the powder coated pushrod? I don't remember having this problem, maybe the powder coating is causing some interference right at the end of the pushrod or maybe some roughness or deformation from cutting the pushrod stock......if necessary, I'd carefully reduce the diameter of the rod ends and not compromise the strength of the pushrod. IF i remember correctly, the rod ends have thicker walls than the pushrod. the fit should be snug before riveting (and after priming)
RV-14A flying 410 hrs
Old 01-24-2020, 05:04 AM
carlrai's Avatar
carlrai carlrai is offline
Default Had same problem with mine:
I was lucky enough to have access to a lathe. I put the threaded end of the fitting into a collet and took off a couple thousandths at a time until I got a good fit in the steel tube. You're basically removing the plating. I was careful to get the now exposed bare steel coated with Akzo primer when inserted into the pushrod.
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 01-24-2020, 05:08 AM
OZCleco's Avatar
OZCleco OZCleco is offline
Just completing an "entry into service" for an RV9A that our club has acquired and we found the aileron pushrods rusting with worn rivet heads from hitting the rear spar. Scary.
Purchased new pushrod material and threaded rod ends only to be confronted with the same fitment problem you have. Lots of threads on that here.
We had the threaded rod ends reduced ever so slightly and welded into the new pushrods per the applicable RV9A drawing. Very happy with the end result.
Paid up 23/01/2020
Old 01-24-2020, 06:33 AM
Allan Stern Allan Stern is offline
Default Push rods
Sorry for my first post that was totally wrong. Was thinking of another thing so I deleted it.
The threaded ends of the aileron push rods are tight. I used a round file to slightly bevel the inside square corners and I might have used a dremel sanding drum to slightly sand the inside of the tube. Or slight sanding of fitting end.
Checking to see how they fit? Once you get them started a plastic hammer will drive them into the tube.
After you might have primed the inside of the tubes. Any primer at end will make fitting hard.
Old 01-24-2020, 06:47 AM
JDA_BTR JDA_BTR is offline
I had to lightly sand mine. When I get bare metal where priming is impractical I put some Boelube T9 on it when assembling. Found at most good bike shops. Leaves a protective waxy film on the metal reducing corrosion.
Ser 104142, RV-14A flying - N1463
Ser 83825, RV-8 building - N8638?
USN Ret, Urologist, AME, Repeat Offender
https://www.atkinsonurology.com
Old 01-24-2020, 09:15 AM
iwannarv iwannarv is offline
I just took a dremel sander in the bore and smoothed it out untill the pushrod would slide in. Re-touch with primer, rivet it in....
Brad Brensing
RV-10 Emp/Tailcone - Complete, QB Wings - Building, Fuse - Building
Never judge a man by his trim tabs.
Old 01-24-2020, 09:19 AM
Bavafa Bavafa is offline
All of my push/pull tubes regardless of material got a nice coat of Akzo primer inside.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 01-25-2020, 06:23 AM
Reflex Reflex is offline
I had the same issue. I chucked the threaded ends into a drill press and lightly touched with emery cloth. This leaves bare steel so a light coat of primer was added. If it's tight after priming, just wet sand lightly. Don't have a picture, but found a picture on Shawn's web site here:
The process worked well for me.
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
