Old 01-20-2020, 03:43 PM
filiperosa filiperosa is offline
Default Trutrak auto trim, what is the part connected?
Hello,
I got a trutrak autotrim with the wiring loom and a small device which I do not know what it is, I was thinking it was an actuator but seams very small.
It was connected to pin 1, 2 and 14 of the auto trim which according to trutrak manual nothing is connected there.
Does anyone knows what this is and how it works?
Filipe
https://photos.app.goo.gl/4EEgT9eiW7WiB84w7
Old 01-20-2020, 05:23 PM
rleffler's Avatar
rleffler rleffler is offline
I don?t know what that is.......
I have the autotrim installed in my RV-10. That part wasn?t a part of my install. The autotrim is just electrically inserted into a couple of the elevator servo lines per the manual.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 01-20-2020, 05:30 PM
andrewtac andrewtac is offline
when I installed the trutrac autotrim it was a module that went between the control head and the servo. It also had two wires to the trim motor, and one to an led indicator light. I wired it according to the diagram. The only issue I had was when I set it up, I set up the trim rate at full (this caused it to trim to fast and would diverge to a severely out of trim state), pick something in the middle and go from there.
Mark Andrew Tacquard
2019 VAF Dues Paid
RV8 N189DK
Old 01-20-2020, 07:26 PM
ALagonia ALagonia is offline
My installation went exactly as described here except we did not have an issue with the trim speed. That LED light was used to set the trim speed. Mine works as designed and the trim speed is at the speed I set it.
Old 01-21-2020, 08:54 AM
Thank you for your answers. The problem I see is that I do not see this part anywhere on the installation manual. It was directly connected to the servo? It to the same point as the servo? You were using only servo or servo and trim motor at the same time?
Thank you a lot,
Filipe
Old 01-21-2020, 09:27 AM
rleffler's Avatar
Thank you a lot,
Filipe
You'll get more specific advice if you let us know what you are building. Autopilots interface slightly different from one model to another.
My RV-10 is installed exactly per the manuals.
Bob Leffler
Old 01-21-2020, 09:28 AM
I am not building a Vans, I am building a Long-ez here in Portugal, however for me this is the best experimental forum online and this is the reason I use it a lot,
Filipe
Old 01-21-2020, 09:30 AM
The picture looks like they included something extra in the box. Maybe that is something they used to test the module.
2019 VAF Dues Paid
RV8 N189DK
Old 01-21-2020, 10:39 AM
rleffler's Avatar
Filipe
The part you showed isn't used on a RV. You might have better luck with a fellow Long-EZ builder.
Bob Leffler
Old 01-21-2020, 11:32 AM
Hello again,
Got the answer from TruTrak:
The item in the picture is a Pitch Servo Push Rod with the Trim Sensor attached. The Trim Sensor is used to tell the system when the Auto Trim needs to run.This is why it is connected up to the Auto Trim Module. If you wish to deactivate the Auto Trim just leave the Trim Sensor disconnected.
Thank you all,
Filipe
