  #11
Old 01-20-2020, 05:52 PM
RV8JD's Avatar
RV8JD RV8JD is offline
Originally Posted by gmcjetpilot View Post
Keep in mind there is NO PERFECT PLACE FOR A STATIC PORT. THE BEST PLACE IS ABOUT 100 FEET BEHIND THE RUDDER..... Seriously.
https://www.youtube.com/watch?v=kZsi4A5PcTw
Using a trailing static cone for A/S calibration, just like the big boys. I was hoping to see comparison data for a cruise point or two.
Thanks for posting that.
Carl N.
Arlington, WA (KAWO)
RV-8, 790 Tach Hours
(Pic 1),(Pic 2)
- Out with the Old, In with the New
(Pic)
RV-8, 1938 Tach Hours (Pic 1),(Pic 2) - Sold
Glasflugel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 01-20-2020, 06:19 PM
mfleming's Avatar
mfleming mfleming is offline
Originally Posted by bjdecker View Post
Just my opinion -- patch it, put the static port in the location as per the plans.
Don't wig-out about the patch; just debur both sides of the hole, slather a little JB Weld on a small piece of scrap aluminum (1/2" square or thereabouts) and glue it to the back side of the fuse skin, scrape off the excess that oozes out, then sand flat when dry.
No...don't do this...the skin is structural. Follow 43:13 to make a patch.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 01-20-2020, 07:03 PM
Sue Sue is offline
Default Hole
Just put in a 1097 #10 rivit.
Old 01-20-2020, 07:29 PM
burtj burtj is offline
I put mine in the wrong place because the idiots at Van's had the plans wrong. Or the canoe was upside down but my thinking wasn't 🛶🙃😅
In any case, I put a flush rivet in the hole and put the port in the right place. Then, because I know how we are, I put another rivet to nowhere in the corresponding wrong place on the other side. Now the wisenheimers at Oshkosh aren't sure if it's a mistake or a super secret mod that they can't live without 😉
Old 01-20-2020, 07:32 PM
Jpm757 Jpm757 is offline
Ralph is right, over the years the static ports HAVE been depicted on both locations. The RV6 plans, RV7 plans and Vans pitot/static kit all may show different locations. I located the static ports on my RV6 & RV7 in the same (old, forward) location, and it has worked just fine. Even the gang at Van's signed off on it. Leave them where they are and build on.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
Old 01-20-2020, 08:10 PM
bhester's Avatar
bhester bhester is offline
Thumbs up They will be fine
I put mine here in 2005 and they have been fine. the directions said to install them here, after I did the drawing showed them further back.
Mine work just like they should.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-20-2020, 08:49 PM
Davea320 Davea320 is offline
May just put in Van?s static port in wrong holes and Safeair ports in new correct holes and tell folks I have a double redundant system.
That?s what makes it unique to the builder right? See if folks at OSH can figure it out.
Dave
RV7 QB started 1/17
Working on FWF
2020 dues sent
Old 01-20-2020, 09:49 PM
RV8JD's Avatar
Originally Posted by burtj View Post
I put mine in the wrong place because the idiots at Van's had the plans wrong. Or the canoe was upside down but my thinking wasn't ������
That's interesting. On my QB RV-8 the Static Ports are much lower than the plans call for, about 4" UP from the lower longeron (but at the correct longitudinal location). They should be 4" DOWN from the upper longeron. It's as if the Static Port holes were drilled at the factory with the canoe upside down and the plans were misread. I have done 3 and 4 leg GPS runs and my indicated TAS is about 4 MPH fast, but I haven't done anything yet to fix that.
Correct vertical location is 4" DOWN from the upper longeron:
My previous QB RV-8 has the Static Ports in the correct vertical and longitudinal location.
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 01-21-2020, 12:21 AM
Cumulo Cumulo is offline
I did a static port mod years ago on a certified a/c to improve the airspeed accuracy, so I've been there.
The general effect of fore and aft location of the static port on the aft side of a low wing aircraft is:
forward toward the wing = higher indicated air speed,
rearward toward the tail = lower indicated air speed.
I have no idea what the effect of vertical location on a slab sided a/c would be, though I guess it would be slight if it is well away from the top or bottom edge.
Related story: I asked why the altitude hold of the company's Aero Commander was crazy. The answer was that it had made the rounds to all the various shops in socal and no one could fix it. I noticed in the air, though, that if I bumped the nose up, the VSI would initially go down then up. Well that was it, it all has to do with the factory location of the static port and the effect of the high wing balanced by the fuselage pressure pattern giving good steady state static pressure results, but poor dynamics. Even the big boys get it wrong from time to time. Be glad you've got Van.
Ron
Old 01-21-2020, 08:13 AM
rvbuilder2002's Avatar
I am 99% sure that the QB assembly facility has never installed static ports so I am pretty sure that mistake was done by the builder.
For the OP, there is a lot of data that indicates that the actual static port that gets installed is far more important than which of the two bulkheads it is coincident too.
A flush static port like was being sold by a couple of the custom parts vendors a few years ago is a guaranty of static errors and instrumentation problems.
Scott McDaniels
Hubbard, Oregon
